Grinding the brake caliper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shemicals, Apr 25, 2011.
  1. Apr 25, 2011 at 2:18 PM
    Shemicals
    Shemicals [OP] Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    I am grinding my brake caliper bracket on wednesday. i will be shaving approx 5 mm off of the piece and I want to know if there is a fluid line that runs through that piece i need to be careful of.
    im talking about the elevated piece that comes out and over like a wide n shaped piece.
    please let me know.
    thanks
  2. Apr 27, 2011 at 11:56 AM
    Shemicals
    Build Page
    so if anyone would give me any advice that would be cool.
    i picked up a rapid metal removal file today and im just going to do it myself. i am only grinding the bracket. no where near any fluid
  3. Apr 28, 2011 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Never a good idea to grind the brake calipers. Some have cracked in the past, and being as its what stops you, you arent going to know if you went too far until you need them the most.
  4. Apr 28, 2011 at 8:12 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    its the new plasti-dip
  5. Apr 28, 2011 at 8:13 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    x2 i wouldnt modifiy something that i trust to save my life
  6. Apr 28, 2011 at 8:28 AM
    Ralph Pootawn
    Ralph Pootawn Well-Known Member
    Fairfax, Va
    '11 Timberland Mica TRD Off-Road
    N/A
    Why the f*ck would you do that?
  7. Apr 28, 2011 at 9:32 AM
    Shemicals
    Build Page
    lol i need to do it to fit my wheels.... im not actually grinding the caliper.... just a piece of cast iron.
  8. Apr 28, 2011 at 9:40 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    can you get me a picture of which peice you are talking about? i have ground calipers in the past and brackets for people that wanted 12" wheels on newer model chevy's and i also bought a tacoma that someone ground the calipers too far before too.
  9. Apr 28, 2011 at 9:44 AM
    Patrobs
    Patrobs Well-Known Member
    Patrick
    New Hampshire
    2012 Dbl Cab Short bed TRD Offroad
    just buy wheelers 1/4" spacers
  10. Apr 28, 2011 at 10:30 AM
    Shemicals
    Build Page
    as far as a picture....
    i have attached it.
    you can see where the arrow is pointed and it looks orange. exactly the same piece total chaos shaves for the long travel kit.
    and for wheel spacers.... with the spacers i only get 3 1/2 hand turns on the lug so they wont put the wheels on....
  11. Apr 28, 2011 at 11:09 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    No fluid running thru that piece, just a brace for the caliper ears. I would think you could get away with 5 mm.
    Give Total Chaos a call and see what they say??. Apparently they have done it in the past and no adverse effects.
    Personally, I wouldn't grind anything on the caliper itself. I would search out longer studs and spacers.
  12. Apr 28, 2011 at 11:15 AM
    Shemicals
    Build Page
    the dealership has studs that are 1/4" longer. do u think that will do the trick with 5mm spacers?
  13. Apr 28, 2011 at 11:21 AM
    AC13JohnG
    AC13JohnG Señor Member
    Black 5 lug
    I ground down the caliper carrier when I put my wheels on with no problems since. It's a pretty stout part, I would'nt worry about it.
  14. Apr 28, 2011 at 11:38 AM
    Shemicals
    Build Page
    yeah man i am going with the caliper grind. i just spoke to my buddy who owns an auto shop and said extended studs are deadly. he doesnt recommend either but because im a friend if he were to lean towards one it would be the caliper.....
    plus extended studs x 10 = $80 + 120 in labor to put them in.
    grinding the caliper = my hands and a file + no spacer = :)
  15. Apr 28, 2011 at 12:00 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Even advice you don't want to hear? Don't do it.
  16. Apr 28, 2011 at 12:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...the best advice is often the most ignored....
  17. Apr 28, 2011 at 1:36 PM
    Shemicals
    Build Page
    woah woah such hostility people.
    i simply asked for advice on grinding the piece.
    stop hating!
  18. Apr 28, 2011 at 1:56 PM
    Shemicals
    Build Page
    when my brakes fail because of my modifications i will be humble but until then im gonna remain a champ!
  19. Aug 22, 2011 at 8:21 PM
    NoLimits
    NoLimits Member
    Barry
    Tulsa
    Black Longbed 4x4
    Any Update on this Shemicals?? I'm running into the same prob with the Pro Comp Series 52 Rock Crawlers I bought. I even stuck a spare 5mm spacer I have on there and it still hits the caliber bracket. Its hard to tell how much clearance I need tho because I cant see everything when the wheel is on there.
  20. Aug 23, 2011 at 8:36 AM
    40950
    CR, WA
    stock
    Stick a ruler on the face of the hub (vertical),,then another one across(horizontal) to that one from the bracket you are hitting. read the numbers needed.
    do the same to the wheel in about the same area.
    Quick, easy and painless.
