Grinding the jack
Discussion in 'Audio & Video' started by ABA180, Apr 10, 2013.
  1. Apr 10, 2013 at 5:33 PM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    2010 single cab. I have a box I would like to use, it will require grinding the 2 seat hook loops and the jack platform behind the seat.
    What is the best way to do this? I would guess either Sawzall or a grinder. I'm leery of the grinder because it will give me a shower of sparks inside the truck.
    Help?
  2. Apr 10, 2013 at 5:45 PM
    slinkey11
    slinkey11 Well-Known Member
    Gabe
    NC
    2015 tacoma
    For the hooks i drilled out the spot welds. i think there was three on each hook. For the jack holder i used a grinder but i did cover everything to avoid any damage that might have occurred from the sparks. Worked out just fine.
  3. Apr 10, 2013 at 6:08 PM
    ABA180
    East Bridgewater MA
    Good deal..tell me, what did you wrap it with? And did you grind top down or bottom up, or on the side? Just trying to build a picture of what to do so I don't mess it up..
  4. Apr 10, 2013 at 6:14 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I had to do a bunch of cutting for my sub box. Access cab tho so different scenario. But sawzall with a good metal blade over a grinder for sure if its possible to make the cut with a sawzall.
  5. Apr 10, 2013 at 6:31 PM
    slinkey11
    Gabe
    NC
    2015 tacoma
    I used what i think are called a grinding blankets. A neighbor that does fab work in his garage let me borrow them. It was basically a thick fire resistant blanket. Other than that i dont know what you could use as there might be a chance the sparks could burn through the material and mess something up.
    I think i hit it from a few different angles but mostly top down though. I am by no means a professional so don't put to much stock in my techniques.
