Grinding when starting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, May 24, 2023.
  1. May 24, 2023 at 3:58 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Starting to get a very quick grind when cold starting. Has only happened twice so far. Does not do it every cold start. Grinding noise lasts like a half second but it’s decently loud. Just hit 300k, could we suspect the starter?
  2. May 24, 2023 at 4:03 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I've had a 5MT do that before on another platform and it was the starter covered in clutch dust. Removing it and giving it a good cleaning fixed it up. It didn't sound anything like the power steering sound, definitely sounded like rotational metal on metal and seemed to fade out as the sound continued (only lasting a second or 2 tops) - I suspect as the starter was slowing down from its initial start. I'd put my money on the starter, probably worth replacing at this point, you've definitely got your moneys worth out of it by now.
  3. May 24, 2023 at 4:32 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Rotational metal on metal is a good way of putting it. What’s the consensus for 1st gens on this.. rebuild it or replace? I see two Densos on rockauto for just over $100. Rebuild kits about $20
  4. May 25, 2023 at 11:29 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    spend the $100. I just had mine rebuilt at a local shop for like $75 when i did my 4x4 conversion.
    Logans2001[OP] likes this.
  5. May 31, 2023 at 2:49 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Update to this:
    It stopped grinding upon start up about 5 days ago or so. Starts up with no noise/grinds. Could this still be the starter? Can a starter temporarily “fix itself” for awhile? I ended buying a Denso replacement. I know I could’ve rebuilt it but with 300k miles I’m ok with spending extra for a replacement.
  6. Jun 1, 2023 at 3:33 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What ever was grinding has removed enough material to no longer grind.
    Things shifted enough to no longer grind.
