Groaning/creaking noise from steering rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IEsurfer, Jul 7, 2022.
  1. Jul 7, 2022 at 6:39 PM
    IEsurfer
    IEsurfer [OP] Well-Known Member
    Socal
    So when I'm parked or going really slow in reverse (backing out of parking) I hear a loud groaning/creaking noise (kind of like a whale calling out underwater). Only happens when you turn wheel to right no noise when turning left.
    I did the obvious, checked power steering fluid, greased all my zerks, verified torque on lca bolts to 100ft lbs
    Truck is a 2010 tacoma lifted on 6112 5160s with camburg upper control arms (uca greased and uniball lubed)
    When I went off roading the other week I noticed a clunk/pop noise coming from front suspension when struts are fully compressed not sure if those two are related.
    Any suggestions? Have appointment with mechanic but he's not available for 2 more weeks
    Has 63k miles on truck suspension is less than 10k miles old
  2. Jul 7, 2022 at 6:54 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    I had a similar noise occur after I had someone increase the preload on my driver side coilover to account for Taco lean. They didn't tighten a sway bar link fully, which caused said creaking sound. If I were you, I would poke around the front end and ensure everything is tight, wiggle parts up/down/fore/aft, etc as that is how I tracked mine down.
    IEsurfer[OP] likes this.
  3. Jul 7, 2022 at 7:16 PM
    IEsurfer
    Socal
    Ok awesome that's a great suggestion I'll check it out!
    SoCOTaco[QUOTED] likes this.
