Groaning Noise Front Left after 3' Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MonkeyWrench462, Oct 31, 2016.
  1. Oct 31, 2016 at 8:06 AM
    MonkeyWrench462
    MonkeyWrench462 [OP] Well-Known Member
    Christopher
    Minnesota
    2013 Tacoma TRD
    K&N Air Filter, Supreme Suspension 3" Lift, Daughters First Pair of vans from Mirror
    I recently installed the supreme suspension 3" lift and also got the front end aligned in my 2013 tacoma.
    I notice a groaning noise from the front left hand side at lower speeds. But only when the truck has been sitting. Seems to go away after roughly a mile or two. Since then I have installed the Diff drop but it did not help.
    If it was CV joint wouldn't it make more noise turning and also not go away??
    Could it be a wheel bearing?
    Any experience this?
    ChadsPride and scottalot like this.
  2. Oct 31, 2016 at 9:29 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    If there's a backing plate behind the rotor, they might have bent it and it's rubbing against the rotor, perhaps?
    or a wheel bearing. or the CV axle binding.
  3. Oct 31, 2016 at 9:35 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    my vote is on needle bearing....
    if it goes away in 4x4 (cruising in a straight line flip it to 4x4) then it for sure is the needle bearing. Replace with ECGS bushing and call it good, also remove the diff drop.
  4. Oct 31, 2016 at 2:07 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    Cool I will test that tonight!! @nd4spdbh....Have installed the bushing in your truck? I like the logic of removing the slop and making The tolerance smaller
  5. Oct 31, 2016 at 3:09 PM
    nd4spdbh
    SoCal
    yup. Instantly noticed the groaning sound on my truck after my 2in lift. Immediatly went away in 4hi. Made a puller tool, pulled out the original needle bearing, and pressed in the bushing to the proper depth as its longer, no more groaning.
  6. Oct 31, 2016 at 3:56 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I did the OME 887's (roughly 3" lift) and started getting the grinding/pulsing vibration up front. Toyota dealer diagnosed it as the Needle Bearing. Replaced it under Toyota TSB/Warranty. That doesn't always permanently fix it though!
    ECGS bushing is not a bad idea. I eventually did ECGS Gears & ARB Air Lockers - thus eliminating the faulty Toyota Needle Bearing. All is well!
    The Needle Bearing issue can also be speed sensitive (I think like 30-45mph).
  7. Oct 31, 2016 at 4:02 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Dang, I was ready to read up on this "3' lift" and disappointed with just a cheap shitty 3" spacer.
  8. Nov 1, 2016 at 9:46 AM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    Did the engage 4x4 test today....Yup its the Diff bearng
    Placed my bushing order with ECGS
    ChadsPride, scottalot and Kyitty like this.
  9. Nov 1, 2016 at 10:22 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Sweet. Goodbye diff groaning! :)
  10. Nov 3, 2016 at 2:26 PM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    I got the tools to install it if you want
  11. Nov 3, 2016 at 2:31 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    Awesome!!!! Thanks!!!! But guess what i ordered with the bushing??? HAHAHA So I might list myself to for Minnesota tool loaner like you did
  12. Nov 3, 2016 at 2:34 PM
    DCLBFTW
    Minnesota
    06 dclb
    We do mod days over at my plce every one i a while one should be coming up soon if you need any help with the bushing ive done 6 or 7 of them
    ChadsPride likes this.
  13. Nov 3, 2016 at 2:35 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    thanks!!! Where you work at a shop?
  14. Nov 3, 2016 at 2:36 PM
    DCLBFTW
    Minnesota
    06 dclb
    Home , i just have a small welding and fab shop and lots of tools
  15. Nov 3, 2016 at 2:39 PM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    Sweet!!! I might take you up on that? Bud light or Miller Light? haaha
  16. Nov 3, 2016 at 2:41 PM
    DCLBFTW
    Minnesota
    06 dclb
    Bud
  17. Nov 12, 2016 at 6:07 AM
    MonkeyWrench462
    Christopher
    Minnesota
    2013 Tacoma TRD
    Installed the bushing yesterday......Groaning is gone!!!!!!!!
    But i have a strange clunk when turning...everything looks tight....I plan to jack it up today and look around. I know I have everything tight
