Groaning sound at 60 mph+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 802yotoclmbr, Sep 28, 2017.
  1. Sep 28, 2017 at 6:07 PM
    802yotoclmbr
    802yotoclmbr [OP] Member
    Eric
    Upton, ma
    09 TRD Off Rd
    3" OME, AEM brute force, AJT design shift knob, shorty atena, atx crawl wheels, cooper discover stt pro's
    I just replaced my warn out OME lift with a fox 2.5 lift well putting the lift in I replaced my needle bearing with the ECGS bushing, new inner seal and bed cv shaft everything is perfect at lower speeds. How ever at highway speeds 60+ mph I have a bad groan coming from the front end near the front diff area. Thought maybe it was a wheel bearing but noise is the same when I turn side to side. It only gets louder as I go faster. Any ideas?
  2. Sep 28, 2017 at 8:25 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Rear pinion angle it sounds like. Check your pinion angle compared to your output shaft angle they should be parallel
