Grocery bags in bed...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by justrfb, Nov 5, 2018.
  1. Nov 5, 2018 at 11:30 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i got a bed mat and a tri fold tonneau cover. i then went to home depot and got a 1" aluminum channel and 12"x1" board (and stained it black).
    i cut and mounted the channel on both sides of bed using the bed storage box screws and cut the board to slide into them for a removable divider.
    perfect for a bunch of groceries, etc and when necessary i easily remove it. OEM divider more flexible but pricey for my minimal use.
    i used a couple of hooks and bungee on cab side of board to thread bungee thru toolbox/random things with handles. probably not necessary but seemed a good idea.
    i did not find a need to use bungee on tailgate side since the mat keeps things from moving around.
    for groceries, i just open the tailgate and pile them in without opening the tonneau cover.
  2. Nov 5, 2018 at 11:33 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    When @shakerhood says it looks cool, you gotta click the link and check it out. haha
    Agreed. I miss the slot in my old f-15o that took the 2x8 at the tail just for stuff like this
    shakerhood[QUOTED] likes this.
  3. Nov 5, 2018 at 12:05 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Best advice here is to get a bed mat at the dealer.
    Boyitz and Pickupman2007 like this.
  4. Nov 5, 2018 at 12:39 PM
    phsycle
    phsycle Well-Known Member
    CA
    I'm cheap. Cardboard box in the backseat floor for stuff. I have a 5-gal bucket bungeed to the bed for milk, ice cream, and other spillable meltable and smellables. (They go in the cab in the heat of the summer). If they're bigger than the bucket, then I tie the bag to the D-clamps like @shakerhood
    All those bed bar net options wouldn't work for me. Too much hassle install/removing, as I use the full length of my bed on a regular basis.
    shakerhood and Gunshot-6A like this.
  5. Nov 5, 2018 at 12:46 PM
    Zion
    Zion Well-Known Member
    Hawaii
    Cement 2018 TRD Sport
    bride in the bed holding the groceries
    knayrb, TomTwo, HIYota and 3 others like this.
  6. Nov 5, 2018 at 12:47 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Bed mat and take turns slow...
    Jeremy4x4, Boyitz and Pickupman2007 like this.
  7. Nov 5, 2018 at 12:54 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I have a bed mat. Nothing slides on it. I also have a OEM Tonnau cover. I just put the heavy items (case of water, case of beer) in first, shove it in and put the bags on the tailgate side. This creates an area that nothing will slide or roll out. That is my method.
    Boyitz and PackCon like this.
  8. Nov 5, 2018 at 12:58 PM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    I got a tailgate net on sale from Amazon for about $12; put small black D-rings, from work, on the inner most cubby screws. Used self tapping screws to mount 1 on each side of my tonneau bracket directly above the cubby D-rings. The net has hooks I made from wire coat hanger and painted black, on the adjustable straps. I keep it up in the bad the majority of the time; takes about 30 seconds to a minute to loosen the 3 straps and unhook it when needed.
    It does a great job of keeping small items and groceries in the last 1/3 of the bed for easy retrieval upon reaching your destination.
    Total cost for me was the Amazon tailgate net because I already had everything else, so about $12.
    CaptainBart45 and Gunshot-6A like this.
  9. Nov 5, 2018 at 12:59 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Bed mat always. Best thing to own.
    You can buy basically a tension rod that goes between the bedsides and situate it so you can put storage bins in front of it just behind your tailgate.
    I know you have the trifold cover so you can flip it up and then put stuff in the bins.
    But honestly after a tonneau style cover and bins... just buy a 4Runner LOL.
    I have the bed mat and a cap. I can put grocery bags just behind the tailgate and things don’t slide as long as I don’t have cans or anything that rolls.
    But I almost always use the backseats or take the Jeep.
  10. Nov 5, 2018 at 1:05 PM
    TC_Mic
    I had the net before the bed mat. The net works either way, weights basically nothing, sits under the cover with no problem, can be removed/replaced quickly, fits inside the small cubby when you need to get it "out of the way".
    It has even been used 2 or 3 times to help secure cargo, when moving stuff to/from storage and moving each of the daughters.
  11. Nov 5, 2018 at 1:29 PM
    AndyGuy317
    AndyGuy317 Well-Known Member
    Andrew
    2018 Super White Tacoma TRD OR
    I had the same problem. Needed a place to hold my work gear that wasn’t the back seat due to 2 child seats. Was a pain to try and cram groceries on the floor of the back seat. I ended up installing a kobalt truck box. It’s not the best box you can get but so far it’s been great to handle groceries on one half and ammo box with air compressor, first aid bag and a roll up beach blanket for the kids soccer games.
    I also have a ratcheting Kargo bar from Amazon that sits between the notched cut out in the bed. Works for what it is and doesn’t cause 200 bucks.
    And like most have mentioned, rubber bedmat is a just for storing anything back there without sliding.
  12. Nov 5, 2018 at 1:40 PM
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
  13. Nov 5, 2018 at 3:02 PM
    jkshel24
    jkshel24 Well-Known Member
    Texas
    2016 Toyota Tacoma TSS
    My mind immediatley wentr here too!! Nothing fancy, and nothing fancy to get stolen!!
    Jeremy4x4 likes this.
  14. Nov 5, 2018 at 3:20 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    You beat me to this.
    PackCon and shakerhood like this.
  15. Nov 5, 2018 at 3:27 PM
    #35
    daveometrod
    daveometrod Well-Known Member
    18 TRD OR 4x4 DCSB Blazing Blue
    I use Rubbermaid Roughneck Storage boxes. That makes it easy to carry in the house compared to a bunch of plastic bags set to rip open at the most inopportune time. I have a bed mat and Tonneau cover. If you're going to buy boxes, consider that some of the lids may allow water to enter.
  16. Nov 5, 2018 at 3:59 PM
    #36
    ms231
    ms231 Well-Known Member
    Westchester ny
    Bedmat definitely keeps things in place.
    I also have the bed extender which when flipped into the bed creates its own natural bed divider.
  17. Nov 5, 2018 at 4:02 PM
    #37
    Tacoma_TTom
    Tacoma_TTom Tys_Taco
    Tyler
    2018 Cement Tacoma TRD OR
  18. Nov 5, 2018 at 4:03 PM
    #38
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    We do have the bed mat, but we just tie the bags up, and drive on and have never had any issues.
  19. Nov 5, 2018 at 4:05 PM
    #39
    CRCs Reality
    CRCs Reality Well-Known Member
    Pittsburgh-Ish
    2017 DCSB TRD Sport (OVTuned)
  20. Nov 5, 2018 at 4:27 PM
    #40
    jkshel24
    Texas
    Don't sleep on the vinyl reusable bags either. I love them! for around a dollar, you can get so much more packed and you don't have to deal with those damn disposable non recyclable ones!
