Grocery shopping in your Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by anonymouscuban, Jan 13, 2018.
  1. Feb 1, 2018 at 10:37 AM
    #121
    syano10
    syano10 Member
    Stephen
    Surprise Arizona
    17' SR5 4X4
    I did the same thing. Did you order the brackets off of Amazon?
  2. Feb 1, 2018 at 12:00 PM
    #122
    anonymouscuban
    anonymouscuban [OP] Well-Known Member
    Alex
    Porter Ranch
    2017 MGM Off Road Double Cab Shortbox
    I ordered them from 4 Wheel Parts just because I could pick them up at their local store. They have the same ones on Amazon.
    Here is the link on the 4 Wheel Parts store:
    https://www.4wheelparts.com/Exterior-Parts-Car-Care/AMP-BedXTender-Quick-Mount-Bracket-Kit-74608-01A.aspx?t_c=3&t_s=120&t_pt=5275&t_pn=AMP74608-01A
    And same thing on Amazon:
    https://www.amazon.com/AMP-Research...ywords=AMP+BedXTender+Quick+Mount+Bracket+Kit
    syano10[QUOTED] likes this.
  3. Feb 8, 2018 at 2:40 PM
    #123
    eurowner
    eurowner Duke Sky
    Scoty
    No problems here
    RobP62 likes this.
  4. Feb 8, 2018 at 3:07 PM
    #124
    svassh
    svassh Active Member
    Scott
    Highland Village, TX
    2016 Tacoma Limited Grey
    none
  5. May 17, 2018 at 6:27 AM
    #125
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    Here's my cheap and very effective solution:
    3 black plastic crates from Office Depot (or Office Max):
    https://www.officedepot.com/a/produ...VEIZpCh2ZRwMcEAYYAyABEgIInPD_BwE&gclsrc=aw.ds
    4 black zip ties (also available at Office Depot)
    2 short bungee cords (also available at Office Depot)
    Arrange the 3 crates lengthwise end to end and zip tie them together to form one long piece.
    Set them in the bed near the tailgate (they fit perfectly, lengthwise)
    Bungee to the 2 galvanized loops on the floor of the truck bed.
    Insert groceries into crates.
    Remove crates when not in use.
    $20 solution. Works with all covers. Does not require rails.
    NMTrailRider likes this.
  6. May 17, 2018 at 7:02 AM
    #126
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I fold the seat down and place my groceries on the back of the seat...
  7. May 17, 2018 at 7:37 AM
    #127
    temujen
    temujen Well-Known Member
    '17 Tacoma OR DCSB
    Awesome - how difficult was it to install these? And do you think they'd be strong enough to serve as cargo tie-downs?
  8. May 17, 2018 at 9:08 AM
    #128
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Extremely easy to install. If I remember correctly, I used the existing bolts to fasten them (not 100% sure about this).
    I use these rings with bungee chords, and in conjunction with the rubber mat, they keep whatever i want "secure".
    I would never use these rings with ratchet straps though, since the tension would rip them right out.
    They are very useful, and out if the way when not needed.
    temujen[QUOTED] likes this.
  9. May 17, 2018 at 10:16 AM
    #129
    trot
    trot Dang.
    Aberdeen Proving Ground
    18 SW TRD OR DCSB P&T
    activate grocery mode crawl control BEFORE taking the curb
    i learned the hard way down at the commissary
  10. May 19, 2018 at 2:53 PM
    #130
    dangeroso
    Jon
    Dallas, TX
    Went grocery shopping today and snapped a pic of the setup. 3 crates fits the bed perfectly:
