Grote LED Flasher
Discussion in '1st Gen. Tacomas (1995-2004)' started by Heavydutydan, Jun 19, 2020.
  1. Jun 19, 2020 at 2:08 PM
    Heavydutydan
    Heavydutydan [OP] Member
    2002 Tacoma TRD
    I have a Grote LED Flasher (Part# 44890) That I tried to use to correct hyperflash when I switched to LED signals up front (replaced the crappy housings and lenses that ARB put in the bumper I bought with sleeker, brighter, LED that are water-tight). This flasher has an additional ground wire which i connected to a known good ground and it doesn't work at all. I'm guessing the pins are opposite or something. Has anyone successfully used this flasher or do I need to get something else? T.I.A
  2. Jun 19, 2020 at 2:39 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
  3. Jun 19, 2020 at 2:41 PM
    Heavydutydan
    2002 Tacoma TRD
  4. Jun 19, 2020 at 3:14 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    Better yet, I went to oreillys and picked one up there, popped right in under my dash and has been working great ever since I put it in. Maybe they will have some at your local one so you don’t have to wait for the one off of Amazon to come
  5. Jun 19, 2020 at 3:29 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I bought my flasher relay from NAPA, I have Feinex T6’s as turn signal on my front bumper and the stock incandescents in the rear.
  6. Jun 19, 2020 at 3:52 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Was this made for our Toyota`??
    Napa NF EP35L has worked just fine for me.
    SkunkMan17 likes this.
  7. Jun 23, 2020 at 8:02 AM
    Ant4x4
    Ant4x4 Member
    2002 4x4 TRD 5-Spd X-Cab
    Thanks guys, Just installed this one yesterday and works great!! Can't believe I didnt find this solution earlier and at first was messing with load resistors, this solution much better.
    2004Taco[QUOTED] and jbrandt like this.
