Ground and Positive Locations - Question
Discussion in 'Technical Chat' started by iJDub, Jan 20, 2014.
  1. Jan 20, 2014 at 4:58 PM
    iJDub
    iJDub [OP] Well-Known Member
    Is there anything bad about grounding an LED device near the device itself (i.e. in the bed area) and then running the power from a relay in the engine bay? Should I run the ground all the way back to the engine bay? Does it matter?
  2. Jan 20, 2014 at 8:00 PM
    Black Pipe
    Black Pipe Well-Known Member
    No need to run the ground all the way from the battery with that light of a current, grind a little paint off the frame and mount with a small ring lug, or find an existing ground location and just use that.
