Ground clearance - something keeping me up at night
Discussion in 'Suspension' started by Ihatetacomas, Oct 17, 2016.
  1. Oct 17, 2016 at 2:35 PM
    Ihatetacomas
    Ihatetacomas [OP] Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    If the lowest part of our trucks, or any truck for that matter is our axles - why lift any higher than that? Sure you gain more ground clearance , droop and compression but wouldn't you be better off off-roading with a geometrically stable suspension warrantied by Toyota without throwing your CV's out of wack?
  2. Oct 17, 2016 at 2:42 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Your Differential is the lowest point. The only way to lift that higher is larger tires. To fit larger tires you need to lift the truck via suspension or body lift.
    Lifting the truck using suspension lifts does provide more ground clearance for the frame and other mechanical hardware though. So lifting the truck does improve over all ground clearance in most cases since you can avoid your differential hitting things simply by driving over the high points on the ground with your tire (as opposed to the high point on the ground being centered under your truck).
    Dynosports likes this.
  3. Oct 17, 2016 at 2:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Stay sleepless till you figure it out.
    Make some drawings, or use a model to figure it out. Pictures vs 1000 words and all that.
    One thing you are correct about. You can have too much lift, and mess up a lot of stuff. But that usually happens more in the poseur crew than in experienced off roaders.
    Manual man74 likes this.
  4. Oct 17, 2016 at 2:49 PM
    BlazingTaco
    BlazingTaco ~,!,,___(•v•)___,,!,~
    Exile
    2016 Tacoma SR5 BBP DCSB 4x2
    Mall landscaping pin stripes.
    Portals. /Thread.
  5. Oct 17, 2016 at 3:00 PM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    If you could just put on 40" tires without cutting everything and snapping axles like crazy, then the ground clearance would be huge. Luckily with IFS vehicles, a nice 2" lift provides a lot of extra front ground clearance, making it very capable.
    Also, that's why a lot of people like to go for a straight axle, to remove those angle issues, but then they start to break birfields.... hahah
  6. Oct 17, 2016 at 7:35 PM
    Dynosports
    Dynosports Throw more parts on it and it will go fast.
    Taylor
    Menifee
    2015 DCLB 4x4
    I thought this was a type O because I have never heard of it before. I love learning new things. :hattip:
