Ground for the center console
Discussion in '3rd Gen. Tacomas (2016-2023)' started by medic7556, Mar 20, 2022.
  1. Mar 20, 2022 at 1:15 PM
    medic7556
    medic7556 [OP] Well-Known Member
    Blue Ridge, Ga
    17 MGM Tacoma SR5 4x4 DCSB
    I have a 17 SR5 that I am wanting to install a rear seat 12 v plug in the center console. The plug I have only has a 1 ft ground wire. Is there a good ground in the center console area?
  2. Mar 20, 2022 at 1:18 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Fish it under the carpet and ground to the seat mounting bolt.
    Easiest ground point I can think of in that area. Otherwise you're going forward and grounding under the gearshift console.
    medic7556[OP] likes this.
  3. Mar 20, 2022 at 1:21 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    bolt hole for the inverter available?
  4. Mar 20, 2022 at 1:23 PM
    medic7556
    Blue Ridge, Ga
    I don't mind taking out the center console, it's where I actually want to secure the ground too. I just didn't know for sure if there was a safe ground in that area
    Rock Lobster[QUOTED] likes this.
  5. Mar 20, 2022 at 1:25 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    There are several grounds in the console. Pick any bolt thats on metal and thats your ground.
  6. Mar 20, 2022 at 1:29 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Yep. Seat mounting bolt goes directly to cab/chassis. Just have to find a terminal big enough to go around that giant bolt. :cookiemonster:
    Otherwise I thought most models have an outlet inside the console. It shouldn't be too difficult to tie into that if you don't plan on using both simultaneously. (I never use the stock console outlet.)
    medic7556[QUOTED][OP] likes this.
  7. May 7, 2022 at 7:40 AM
    scott0_1
    scott0_1 Well-Known Member
    Scott
    2017 DCLB TRD Sport
    I'm curious if you ended up finding a good ground?
    I'm doing the same install.
  8. May 7, 2022 at 7:52 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    For low current items like power ports most any attachment point under the console to body will work.
    Generally it is better to run a ground back or from the battery for higher current applications because the frame strap ground in the engine bay carries all new loads to frame and if any of the body to frame grounds fails you can have issues.
    I ran a dedicated ground (and two hots) to my console area with auxiliary fuse panel. This gives me an always on port for cell phone charging. (It’s a bit more than that including an isolation battery- see my build thread for details on that).
    net net any clean screw to bare metal underneath the console for a 10 or 25 amp port should work fine.
    scott0_1 likes this.
  9. May 7, 2022 at 7:55 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Any place in the console will work fine. I'm grounded on the bracket bolt above the inverter.
  10. May 7, 2022 at 8:01 AM
    scott0_1
    Scott
    2017 DCLB TRD Sport
    I was eyeing those bolts up, but they looked way too easy! Not my usual style, and I would be surprised if the universe would allow it to happen!
    I'll give them a try!
  11. May 7, 2022 at 8:42 AM
    Plain Jane Taco
    USA
    In my 2nd gen they were fine. I used it for a constant-on 12v port for the rear passengers.
    scott0_1[QUOTED] and Cudgel like this.
