Ground wire for add a fuse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by th365thli, Nov 3, 2017.
  1. Nov 3, 2017 at 2:19 PM
    th365thli
    th365thli [OP] Well-Known Member
    Jerry
    Bay Area
    2019 Ram 1500 Big Horn Quad Cab
    Apologies if this is in the wrong area.
    I'm installing a USB port in the left console/cubbyhole area blank switch. I'm doing it through an add a fuse. I understand how the add a fuse works. However, where does the ground wire from the new usb port go? Do I have to attach it to a metal piece or is there an easier way?
  2. Nov 3, 2017 at 2:21 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Look around near the fuse box and you'll find a couple bolts and nuts---just attach to that. Thats what I did for my radar hardwire
    th365thli[QUOTED][OP] likes this.
  3. Nov 3, 2017 at 2:26 PM
    th365thli
    Jerry
    Bay Area
    Thanks!
    Did you have to solder it on there or is there a simpler way.
    *edit* nvm, i'm such a noob, i just wrapped the wire around the screw and screwed it back in. Covered it with electrical tape.
