Ground Wire Issues.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Davo53209, May 15, 2020.
  1. May 15, 2020 at 8:09 PM
    Davo53209
    Davo53209 [OP] Well-Known Member
    Chewed Up Tail Light Harness/98 Tacoma SR5
    Okay everyone, what I've decided to do is this.... First, I plan to get under the vehicle to see what it is that I exactly have and then I'm going to attempt clean the ground terminals attached to the engine block with a scrub brush and vinegar.
    Secondly, if that doesn't work, I will then attempt to effect repairs, seeing how I've already bought a 4 gauge, 49 inch cable for the negative ground that's attached to the engine block. If whatever I find deems necessary, I will also replace the positive cable as well.
    Finally, if neither one of the cables appear to be damaged or corroded, what I will do then, is check the tension of the alternator belt, before checking the condition of the alternator.
    While doing all of this, I may even decide to take pictures of what I'm doing, given that someone else is bound to run into this problem at some point in the future. We will have to see how it goes.
    RedManRocket likes this.
  2. May 16, 2020 at 3:14 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is quite easy to measure the length of the cables it does not hurt to be a few inches to long
