ground wire
Discussion in '1st Gen. Tacomas (1995-2004)' started by PLIQUOR519, Nov 24, 2022.
  1. Nov 24, 2022 at 4:02 PM
    PLIQUOR519
    PLIQUOR519 [OP] Active Member
    Romell
    1998 Toyota Tacoma prerunner
    does my ground from the battery to the sidewall have to be the one that came in the truck, or can i just make another hole to mount it?
  2. Nov 24, 2022 at 4:05 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You can make another one.
    But it needs to tie to the body.
    That’s the main body ground for body.
    There is usually an engine ground on the back of one of the cylinder heads and is also tied to the body. So, you definitely need the ground to be good.
  3. Nov 24, 2022 at 5:24 PM
    PLIQUOR519
    Romell
    thanks, right..... the one at the back was all ate up so i replaced the wire but i can't get the screw back into the motor..... and the screw on the fender broke and i made a new hole right next to it.
    TnShooter and Steves104x4 like this.
  4. Nov 25, 2022 at 10:15 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Yeah bad grounds and vacuum leaks plague these when they get old.....
    Keeping with my over kill ways.....did high temp silicone on the hoses..
    And for ground I slipped a braided cable into plastic tubing and ran a ground directly from neg post to computer mount on intake plenum......
    .....there's two cylinders firing simultaneously off that ground.....
