Grounding CB antenna on roof rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by t.hornstra, Jul 30, 2013.
  1. Jul 30, 2013 at 12:24 PM
    t.hornstra
    t.hornstra [OP] Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Hey guys,
    Thinking about getting a baja rack or moving my bed rack to my roof. In order to free up my bed for a cap later on.
    Since my CB is on the inside of my bed, I'm thinking about mounting it on the roof rack to get it higher and above the cab.
    Would the rack alone provide enough ground for the antenna?
  2. Jul 30, 2013 at 9:13 PM
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    No. Chances are the mounting brackets have a rubber gasket making the only metal to metal contact through the bolts. The ground should be body metal as this helps with the ground plane to aid proper signal radiation.
  3. Jul 30, 2013 at 9:54 PM
    mr2mki
    mr2mki Well-Known Member
    You could try mounting it *outside* the bed, either with an outside mounting kit or with an inside mounting kit and some sheet metal that runs the antenna outside the bed.
  4. Jul 31, 2013 at 10:29 AM
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    Yea I've thought about running a BAMF mount off the tailgate. I just think I'd get a lot more reception if I had it up on the roof.
    Isn't there a baja basket that mounts to the roof using the pre-existing holes? Figure if the rack is all metal, the bolts to the roof are metal, and I was able to shave off enough paint to get a good enough contact it should theoretically work.. theoretically.. haha I might just say F it and run a Lil will NMO behind the bed basket
  5. Aug 1, 2013 at 10:15 AM
    mr2mki
    Running it on the roof will indeed give you more reception, but the question is whether the improvement will be more than the loss from grounding it on the basket. Grounding through a basket through some bolts works fine for lots of things, but radio antennas operate at high frequencies and the normal rules of electricity start to break down.
  6. Aug 1, 2013 at 11:38 AM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    Couldn't you run a ground wire up to your antenna bracket? I think flat braided strap is the best. Make sure you tune your antenna with a SWR meter.
  7. Aug 1, 2013 at 2:26 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
