Grounding CB Antenna
Discussion in 'Audio & Video' started by dysfunctnlretard, Oct 3, 2009.
  1. Oct 3, 2009 at 4:17 PM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2021 Jeep Rubicon
    I got my CB radio today and my firestick antenna kit. The kit comes with directions that say the antenna mount must be grounded. Was wodndering how you guys ended up doing this? (grounding the mount and location of your mount). My mount is this one:
    http://www.rightchannelradios.com/mirror-3-way-cb-mounts-85/firestik-3-way-cb-mirror-mount-239.html
    I want to mount it somewhere in the bed but don't know where/how to ground the mount. I have a bedliner too (the plastic ones that usually come on the tacos)
  2. Oct 3, 2009 at 4:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can install the mount wherever in the bed you want to, but you'll need to make a ground wire from the mount to the frame of the truck........and i'd use 8 gauge wire to do so........10 gauge will work decently as well.
  3. Oct 3, 2009 at 4:31 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
  4. Oct 3, 2009 at 4:32 PM
    Monkeysuncle
    Kevin
    Florida
  5. Oct 3, 2009 at 4:33 PM
    Monkeysuncle
    Kevin
    Florida
  6. Oct 3, 2009 at 4:38 PM
    Monkeysuncle
    Kevin
    Florida
    with my bed liner removed I removed the tie down hook, ran a ground to the hole, replaced hook,and the bracket I made and put the liner back in, I have a metal bed, you will have to run a ground to the frame. I braised the bracket, but you can buy flat stock from ACE. Home Repo or lowes and bolt it together with little effort, I made sure to use dielectric grease on my ground to make it water-weather proff
  7. Oct 3, 2009 at 4:44 PM
    Monkeysuncle
    Kevin
    Florida
    I still dont have it hooked up because I found a webpage telling you how to "boost" output on a stock cb, and well, I can hear ya, I just cant brodcast anymore...some things you just shouldnt mess with...
  8. Oct 3, 2009 at 4:49 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Now when you say to ground it to the frame, this means ANY metal part of the truck where I can get good contact? And um guessing I'd just use a screw to ground it right (use it to bolt down the wire)?
  9. Oct 3, 2009 at 4:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    easiest way i have found is to use and eyelet, and find a spot on the frame where there is already a bolt......loosen it and put the ground wire there.
  10. Oct 3, 2009 at 4:59 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Yeah but don't forget about 'ground plane' see firestik's site or google.
  11. Oct 3, 2009 at 4:59 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Nice. That's exactly what I'll do (eyelets with some 8 gauge wiring). While i'm at it I may do some dust lights too. I'll make it a personal mod day. Thanks a lot for all your help guys!
  12. Oct 3, 2009 at 5:01 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Crap. What's this "ground plane" you speak of? Jesus this is getting more technical than I expected. I guess it's good though, it's an opportunity tto learn.
  13. Oct 3, 2009 at 5:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the ground plane is where the antenna will pick up the best reception....which would be right on the roof. i got canada's(member on here) tuned
  14. Oct 3, 2009 at 5:12 PM
    Monkeysuncle
    Kevin
    Florida
    A friend of mine had a truck with a cb in the 1970's,( I am in Florida) the Indian river is salt water and he used to pull up beside the river bank and run a wire(attached to his cb or antena or truck, I don't know which yet) with a metal plate attached to it to the salt water, he said it made ground much better, his broadcast was better, I'll see him on Monday, but I'm guessing the H20 being saline made a difference, or just water in general, he can give me more info on grounding a cb, a better ground plane giver a cleaner signal I think, some one help me out here.
  15. Oct 4, 2009 at 3:56 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Do you guys know if I could ground with 16 gauge wire?
  16. Oct 4, 2009 at 3:59 PM
    Menametony
    Menametony Well-Known Member
    Tony
    Oahu
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar, OEM bed mat, softtopper. WeatherTech Mudflaps On order dissent bed rack and retrofits.
    not exactly sure.. 12 might work? whats powering it.. i heard a rule of thumb is to use the same size as the power source?
  17. Oct 4, 2009 at 4:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you could.......but 12 or 8 would be better. or you can do as i have done......add a few strands of 16 gauge together and tape it up.....it will woprk the same as a larger gauge will.
  18. Oct 4, 2009 at 4:08 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    well Im talking about the antenna. I need to ground it. Im not exactly sure where its getting power from. Im guessing the coaxial cable coming from the CB radio itself.
  19. Oct 4, 2009 at 4:40 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    alright I think a few strands of 16 is the way Ill go with. Im gonna use eyelets at the end of the wire to hookup to the mount and chasis, so should I stick two wires in one eyelet or use two eyelets (both on chasis end and mount end)?
  20. Oct 4, 2009 at 4:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just use a bigger eyelet and run the 2 wires together to make up the one.
