Grounding in the Rear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hotdog, Jul 16, 2009.
  1. Jul 16, 2009 at 8:30 AM
    Hotdog
    Hotdog [OP] My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'm running a 12V outlet to the storage bins in the truck bed. Would you run a pair of wires, so that you could run the ground back to the distribution block or would you ground it back there?
    If you would ground it back there, are there any easy places that you would recommend?
  2. Jul 16, 2009 at 8:37 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Drill a hole in the frame and run a short wire to it. Bolt it in place and you're set. Seriously, it's cake and will be the best ground you'll find.
  3. Jul 16, 2009 at 8:54 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Thanks. I'm always skeptical about drilling into the frame for fear of rust. I probably shouldn't worry, I don't offroad and I'll never drive on salted roads.
  4. Jul 16, 2009 at 8:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    After you drill the frame, and make the connection, spray some underbody protector on it. You can find the stuff at Napa. It works well.
  5. Jul 16, 2009 at 8:55 AM
    mjp2
    NJ
    Between the salted roads and salt spray from the ocean our vehicles are pretty much doomed around here.
  6. Jul 16, 2009 at 9:01 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    that sounds better than what I was planning on doing...I was going to gob some grease over it. :eek:
    derail away. Don't forget the salty women up there...
  7. Jul 16, 2009 at 9:05 AM
    martie
    martie mjp2 is living vicariously through me.
    smartie pants
    NJ
    2015 Ford Explorer Sport
    You think you're some kind of handyman or something?
  8. Jul 16, 2009 at 9:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :popcorn:
  9. Jul 16, 2009 at 9:06 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    speaking of derail, i always ground in the rear... bo dom che
  10. Jul 16, 2009 at 9:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yourself?
  11. Jul 16, 2009 at 9:07 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    well, I do have a functional truck. :cool:
  12. Jul 16, 2009 at 9:08 AM
    martie
    smartie pants
    NJ
    That's quite some talent he has there.
    Yeah, I'm going to need proof of this.
    Plus, mjp2 has a functional truck. It just doesn't go very straight.
  13. Jul 16, 2009 at 9:17 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    you didn't need proof from Mike before he took you home in his civic.
    are you speaking of the Ford?
  14. Jul 16, 2009 at 9:18 AM
    Burgman
    Stephen
    Ric VA
    NO
  15. Jul 16, 2009 at 9:20 AM
    mjp2
    NJ
    Technically, I drove off in the Civic alone and left her wanting more.
  16. Jul 16, 2009 at 9:21 AM
    martie
    smartie pants
    NJ
    He definitely did not take me home. And especially not in the Civic.
    The Tacoma, fool.
  17. Jul 16, 2009 at 9:26 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    are you saying that the truck still is it done :D
  18. Jul 16, 2009 at 10:02 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    neither does mike...:bananahammockdance:
  19. Jul 16, 2009 at 10:05 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    whoa whoa whoa, nobody wants to see the banana hammock dance.
  20. Jul 16, 2009 at 10:07 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    No need to drill the frame. Use the bumper bolts in the rear.
