Grounding issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Adunne, Jan 31, 2023.
  1. Jan 31, 2023 at 12:49 PM
    Adunne
    Adunne [OP] New Member
    03 Tacoma trd xtra cab
    Little modifications
    Hi everyone, so I have a weird issue going on with my Tacoma. I was up in the hills and backed into a tree and broke a tail light, so I bought some OEM style taillights tinted and now I have a major electric issue. I only have my drive side driving light in the rear and when I hit the brakes my blinker light on the dash turns on the driving light goes out and my right reverse light turns on as a brake. I also have led cubes in the bumper and when in reverse and brakes are applied the driver side cubes goes out(yes I tried removing the cubes) nothing changed any thoughts?
  2. Jan 31, 2023 at 1:03 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Please define "OEM style". Aftermarket tail lights can be hit-and-miss, and can contain wiring issues right out of the box. What brand did you get? A lot of us have had good luck with the TYC brand Certified head lamps from Rock Auto. :notsure:
    Otherwise, if you're familiar with how to use a multimeter and trouble shoot circuits, get yourself a digital copy of the Factory Service Manual (FSM), and pull up the wiring diagram. Google "2003 tacoma FSM". should be able to find the pdf pretty easily.
    HondaGM likes this.
  3. Jan 31, 2023 at 1:43 PM
    Adunne
    VIPMOTOZ Smoke Red Lens OE-Style Tail Light Lamp Assembly For 2001-2004 Toyota Tacoma Pickup Truck, Driver & Passenger Side https://www.amazon.com/dp/B0743YTM2W
    these are the tail lights I went with. But before buying these I had a friend give me the stock tail lights out of an older 1st gen Tacoma and I was having the same issue. I have been doing a little testing on it but I was just wondering if I could get a better starting point on where to test
    HondaGM likes this.
  4. Jan 31, 2023 at 1:49 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Confirm the new tail lights work. This will require jumping the non performing side.
    HondaGM likes this.
  5. Feb 1, 2023 at 4:43 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Does your truck have the evil converter box for a 4 pin trailer harness ??
    I wonder did the impact cause that to be damaged?
    ****Physical damage to the wiring harness or the light connectors that was missed.*****
    Plain old aftermarket quality control.
    unplug the new light see if things work as they should with your meter .
    Happy Hunting!!
  6. Feb 1, 2023 at 3:07 PM
    ToughTaco99
    ToughTaco99 Well-Known Member
    Jerry
    1999 White Tacoma Base
    Exhaust
    Shot in the dark but I had similar issues with my Taco. I went to every extreme but still had no luck and I was using OEM tail lights. I had about given up when one day I was detailing it and took the seat out and found a wire pulled out of the harness that clips to the floorboard under the driver side. Stuck it back in and whamo, everything works as it should. Worth a look I suppose.
    Andy01DblCabTacoma likes this.
  7. Feb 2, 2023 at 9:09 AM
    Adunne
    It does not have the trailer plug on. Also I will pull the seat out and take a look!
  8. Feb 2, 2023 at 9:11 AM
    ToughTaco99
    Jerry
    Exhaust
    You may get lucky and be able to see if with it in but I wasn’t that fortunate.
  9. Feb 2, 2023 at 9:49 AM
    lindsayclan
    lindsayclan Member
    2004 Silver Dbl cab Tacoma 4x4 SR5 3.4L
    2" level kit. Bull/brush guard. Under armor stock. K&N cold air intake.
    I am currently experiencing my passenger side running lights not working. I also purchased those same taillights. Did you ever figure out your issue?
