Grounding point near P/S pump and oil dipstick right engine side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 6, 2022.
  1. Dec 6, 2022 at 8:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Mega bastard to get to, honestly you can likely mount the ground anywhere else. Maybe the dip stick mount?
    I don't believe it's the cause of your issues though.
  2. Dec 6, 2022 at 8:55 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    For reference, check out this video starting at 3:06 to see the ground strap mounting location.
    foampile[OP] and Dm93 like this.
  3. Dec 7, 2022 at 9:43 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    i am pretty sure that's it, thanks
  4. Dec 7, 2022 at 11:45 AM
    foampile
    Mid-Atlantic
    Either that (attached the ground terminal to the same 10 mm bolt that the cable clip goes on the P/S pump) ... or ... the tightening of the bolt securing the electrical connector to the differential ... WAS IT !! The engine running now, so far, so smoothly !!
    TnShooter likes this.
  5. Dec 8, 2022 at 8:20 AM
    foampile
    Mid-Atlantic
    evidently, you never mounted the A/C pump, specifically the lower rear bolt of the 4... this is a cakewalk in comparison
  6. Dec 8, 2022 at 8:33 AM
    Bishop84
    I’m actually a life long Toyota tech. I’ve changed frames on these trucks.
    The worst on the whole truck is the knock sensors. You technically need to remove one cylinder head to get them lol. I’ve done it without.
    Glad you got this sorted out!
    Torspd likes this.
  7. Dec 8, 2022 at 8:36 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Glad you got it sorted out. I was just coming in to say that the ground on the back of the power steering pump won't cause a no start. It's for a pressure switch on the pump that will jump the engine RPM's a few hundred when the pump needs it.
    I switched to an aftermarket pump and left that ground wire (and the pressure switch connector) disconnected.
  8. Dec 8, 2022 at 8:49 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You cut the coolant bypass bracket?
    Or were you actually able to fish them out ?
  9. Dec 8, 2022 at 8:58 AM
    Bishop84
    loosen pipe then black magic
    Torspd and TnShooter[QUOTED] like this.
  10. Dec 8, 2022 at 11:08 AM
    foampile
    Mid-Atlantic
    I agree but the worst SINGLE bolt to torque the the lower rear of the AC pump
  11. Dec 8, 2022 at 11:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Blows my mind how foam talks shit about professionals and then routinely comes back in here to beg for help
  12. Dec 8, 2022 at 1:25 PM
    foampile
    Mid-Atlantic
    so what if he's a professional? so what if i ask for help? professionals are wrong all the time, my doctor is wrong -- i go get another doctor, also a "professional" who disagrees with the previous one. they can't both be right but they can both be wrong.
    professional/certified doesn't mean much. i've got more help from knowledgeable non-professionals.
    by your logic, people would never get second opinions because it would mean they dIsAgReE wiTh a pRoFeSsiOnAl
  13. Dec 8, 2022 at 1:51 PM
    Bishop84
    This is what he means.
    This comment was super petty, but you do you.
    I don’t care either way.
    TireFire likes this.
  14. Dec 8, 2022 at 1:53 PM
    foampile
    Mid-Atlantic
    I am not sure I understand your point
  15. Dec 8, 2022 at 1:59 PM
    #35
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    EatSleepTacos likes this.
  16. Dec 8, 2022 at 2:04 PM
    #36
    TnShooter
    Deogee
    STOCK
    The point is, people here don’t tend to forget.
    Whether you know it or not, you actually had some real good guys try to help you.
    You ran some of them, and some stayed. I’m no professional by any means, but the way you respond to some people can be condescending. I personally, don’t let much get to me.
    For the most part, I don’t care to help people. Even if they have a different opinion of me.
  17. Dec 8, 2022 at 2:24 PM
    #37
    foampile
    Mid-Atlantic
    they were bullies who assumed the right to be condescending themselves... maybe because they are "professional" and think they shouldn't be scrutinized. maybe i am not completely clueless because i get shit done so the bullied hierarchy/tyranny of arbitrary professionals does not support itself.
    if my doctor denied me legitimate scrutiny, i would go get another doctor.
    yet you were more helpful than professionals. so being a professional doesn't really mean much other than feed their ego. i really don't need professionals for anything other than write me prescriptions without which i can't get at the pharmacy. because that's the law, and is tyrannical.
