Grounding the throttle control to the negative post on the battery to get rid of the lag?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dadabill, Sep 24, 2021.
  1. Sep 24, 2021 at 2:08 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    And, make sure and keep detailed records. Maybe the collective can benefit from the RADHAZ data :thumbsup::D
    davidstacoma[QUOTED] likes this.
  2. Sep 24, 2021 at 3:57 PM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    you can also send the signal over your cell phone line for when you need long distance
    Skydvrr and davidstacoma[QUOTED] like this.
  3. Sep 24, 2021 at 4:07 PM
    YellowFootPrints
    YellowFootPrints Well-Known Member
    2021 Tacoma TRD-OR
    Zero
    Gave it a try and it works, I now also can pick up classic country fm station 93.5 with better reception also.
  4. Sep 24, 2021 at 4:11 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    TGIF. Get the tune, OP
  5. Sep 24, 2021 at 4:12 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Is the speed of light not fast enough already? We need those throttle control electrons to go faster!!!!
  6. Sep 24, 2021 at 4:13 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Kramer would go
  7. Sep 24, 2021 at 4:22 PM
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Hey the speed of an electronic signal is only 0.5 to 0.99c, (speed of light in a vacuum). If you want to eliminate throttle lag completely we'll need to incorporate a particle accelerator.
    Stocklocker[QUOTED] likes this.
  8. Sep 24, 2021 at 4:33 PM
    Stocklocker
    17TRDORDCSBAT
    I think if we could run a cable from the driver’s mind to the throttle, so it anticipated the driver’s thoughts, we could finally eliminate all throttle lag in the Tacoma. It’s fairly important, being that Tacomas are developed for Racing, by Toyota Racing Development. Every micro-second counts when you are racing!!!!
    Photo is from recent trials of the new throttle in Japan, led by Mike Sweers:
  9. Sep 24, 2021 at 4:34 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Wait.........
    Did you say to ground the positive or negative cable?
    I luv Fridays on TW
  10. Sep 24, 2021 at 4:38 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Lol. Ever seen that commercial where the couple is trying to figure out a mystery switch and it's operating a garage door 3 doors down?
    Kev250R, Skydvrr and davidstacoma like this.
  11. Sep 24, 2021 at 4:38 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
  12. Sep 24, 2021 at 4:46 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    WiFi/key fob range extender implants
  13. Sep 24, 2021 at 4:49 PM
    Lt. Dangle
    Ohio
    All seriousness aside, the easy play is just to swap the leads on the battery.
    Don't.
  14. Sep 24, 2021 at 4:52 PM
    Mastiffsrule
    Scott
    So put the positive cable on the negative terminal and vice versa?
  15. Sep 24, 2021 at 4:54 PM
    #35
    Lt. Dangle
    Ohio
    ...sure.
  16. Sep 24, 2021 at 4:54 PM
    #36
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I tried it. And I can report absolutely no lag anymore.
  17. Sep 24, 2021 at 4:57 PM
    #37
    Mastiffsrule
    Scott
    I hear if you actually do that and then run a wire and bridge the terminals you can achieve time travel. BUT only if you have a Pedal Commander and OV tune installed at the same time. :thumbsup:
    Stocklocker and Lt. Dangle like this.
  18. Sep 24, 2021 at 4:58 PM
    #38
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    This used to be a thing on Nisan forums. I had a maxima that had starting issues.
    so you add 3 grounds. Throttle body to chassi. Transmission to body. Engine block to body.
    made the starting issue go away and apparently people got more clear audio
  19. Sep 24, 2021 at 5:24 PM
    #39
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Negative get tuned way better
  20. Sep 24, 2021 at 5:37 PM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    Here's another helpful comment, Billy to Billy.
    Don't go for this pedal placebo either.
    If you must change something, get a real tune.
