Grounding Throttlebody?
Discussion in 'Performance and Tuning' started by NC15TRD, Jun 6, 2011.
  1. Jun 22, 2011 at 7:35 PM
    #201
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Gotcha. Yea I would go your route. Or just use a little 2" piece of wire to go between the posts on the speakers.
  2. Jun 22, 2011 at 11:49 PM
    #202
    pizza
    pizza Active Member
    Phoenix
    2010 Tacoma TRD 4x2
    Stock right now.
  3. Jun 23, 2011 at 5:40 AM
    #203
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    right, but just using a lot less speaker wire ;)
    I hardly know anything about home speaker setups so dont take my advice! Im just here for the lol's and :popcorn:
  4. Jun 23, 2011 at 6:24 AM
    #204
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  5. Jun 23, 2011 at 6:36 AM
    #205
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  6. Jun 23, 2011 at 6:37 AM
    #206
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    True, If I go spend an afternoon doing this. What would be the best way to measure success or progress??
  7. Jun 23, 2011 at 6:40 AM
    #207
    Pugga
    Massachusetts
    I'm actually not sure... :eek: I think that other post definitely shows the benefit to having clean, uncorroded wiring though! As far as grounding the throttle body goes, so far the only results seem to be 'it feels like it shifts better' or improved throttle response.
  8. Jun 23, 2011 at 6:44 AM
    #208
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yea, and better shilfing means nothing in my standard tranny lol
  9. Jun 23, 2011 at 6:54 AM
    #209
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  10. Jun 23, 2011 at 6:59 AM
    #210
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I would be doing it expecting lil to zero improvement. But I spend an hour and a half in my vechical driving everyday, if theres a difference it'd notice. Most accurate butt dyno ever!
  11. Jun 23, 2011 at 7:06 AM
    #211
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    lol. go for it and see what heppens. i dont think it would hurt anything.
  12. Jun 23, 2011 at 7:07 AM
    #212
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    Check the voltage on the battery then turn your lights on and check. There will be a 1-2volt drop and the engine might even get pulled down by the load yet you will not fell the difference when you drive. Thus proving my point that electrical load poses little to no difference in performance.
  13. Jun 23, 2011 at 7:17 AM
    #213
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    If the engine gets pulled down, that would be a drag on performance now wouldn't it...
  14. Jun 23, 2011 at 11:23 AM
    #214
    JKD
    JKD Well-Known Member
    If the existing grounds are bad or marginal, I can see how additional grounds might help.
    For those who wonder how grounds might help performance, a higher system voltage produces a higher secondary voltage from the coils -- a hotter spark.
  15. Jun 23, 2011 at 11:41 AM
    #215
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Exactly, thats why it apparently improves
  16. Jun 23, 2011 at 11:43 AM
    #216
    Pugga
    Massachusetts
    I still don't see how grounding the throttle body would come into play. I would buy your argument for grounding various other parts, but I don't see how grounding the throttle body would do anything to improve performance.
  17. Jun 23, 2011 at 11:59 AM
    #217
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    it might make a hotter spark but that really has no effect on power. the only effect it might have is a hotter spark plug tip leading to preignition
  18. Jun 23, 2011 at 12:05 PM
    #218
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Please, drag this thread out into a field and bash it in the face! I beg of you!
  19. Jun 23, 2011 at 12:11 PM
    #219
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Are you the fatty kid in the sig??
  20. Jun 23, 2011 at 12:13 PM
    #220
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    THAT EXPLAINS EVERYTHING! HE'S LIVING OFF OF HIS GOONIES $$$
    :rofl:
