Grounding Throttlebody?
Discussion in 'Performance and Tuning' started by NC15TRD, Jun 6, 2011.
  1. Aug 25, 2012 at 1:40 AM
    #241
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    interesting. i need more people to try it, or input.
  2. Aug 25, 2012 at 6:57 AM
    #242
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just throwing this out there. The only mod I have done to my TB, is put a turbo before it. :cool:
  3. Aug 25, 2012 at 7:46 AM
    #243
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    Is this for 1st gen too or only 2nd ????? And how does it help to ground it....
  4. Aug 25, 2012 at 10:53 AM
    #244
    joes06tacoma
    Joe
    Central Coast, CA
    Get a couple of NOS stickers for the back window. That will add at least 25 HP. This ground mod is only good for about 2HP. I butt dynoed it.
  5. Aug 25, 2012 at 12:31 PM
    #245
    Hurtin Albertan
    Hurtin Albertan Free Man
    Duck
    on the road less traveled
    The mud hides the tree scrapes in the paint
    Huskyliner floor mats
    I wonder if it will help with the barrel roll?... :) kidding... My truck has been a dog lately so time to clean the throttle body and MAF. My serious question for those who claim results is this: What grade fuel have you been using?
  6. Aug 25, 2012 at 1:01 PM
    #246
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    PMK touched on it... there is no other explanation (IF it actually does anything beyond the psychosomatic butt-dyno).
    The TPS is a fully contained electronic unit.
    The throttle control servo is a fully contained electronic unit.
    Having 300 ohms or 300k between the throttle body itself and the chassis means nothing to these components... they have their own grounds, and you could verify that, but I would not because applying your meter to the wrong wire could damage the ECU logic circuit (ohmmeter works by applying a voltage and measuring the current flow).
    But the throttle body is connected to a composite intake manifold, and a plastic airbox. I would expect the TB itself to show a high resistance to ground... the 300 ohm or 300k readings seen might be the result of conductance of the composite intake manifold (it will be conductive if it contains carbon fiber).
    The only thing that grounding the TB can possibly do is bleed off static... but you still have the issue of static in the rest of the intake ducts.
    We MIGHT be seeing static buildup in the TB setting up some kind of capacitive influence on the TPS feedback.
    Will the mod help? Good question, and not one that can be answered on the dyno, because we're talking throttle response/driveability benefits... it's not something that can be measured on anything except the "butt dyno"
    But the mod can't hurt anything.
    For those asking about the wire size, which screw to use, etc....
    It doesn't matter.
    You are simply grounding the body. There is no current normally flowing. There is nothing connected to the screws other than the TB.
    You could use any of the screws... you could even just braze the wire to a hose clamp and wrap that around the TB.
    Wire size? Again, doesn't matter. A proper static discharge system will actually run through a 10meg resistor to prevent circuit (or technician) damage caused by a current surge to ground. You don't WANT a lot of current flowing... and if the wire is always connected, you won't build enough of a charge to cause more than a couple of nano-amperes to flow.
    A piece of 32ga wire could do the job... but for practical applications, I won't use a wire smaller than 18ga stranded in a vehicle, and I won't go smaller than 16ga stranded in anything directly connected to the engine. This is simply for durability due to vibration and weather.
    Some people need to go back and review electronics 101.
    Ohms are units of resistance.
    Mhos are units of conductance.
    zero ohms = no resistance
    No resistance = infinite current flow
    Open circuit /= no resistance
    Open circuit = no connection, no conductivity, no current flow.
    True, you can't truly have zero ohms without a superconductor, but for all practical application purposes, if a meter reads zero ohms, you have a dead short... NOT an open circuit. Anything less than 0.05 or 0.005 or however sensitive your meter is can be considered "zero" for the sake of the measurement.
    An open circuit would be infinite resistance, normally indicated on a digital meter by "0l" or "0r", and of course, the needle at "infinity" on an analog meter. I used to use a 12-digit digital that displayed "0vr-range"... overkill, but it was a $2000 Beckman.
  7. Aug 25, 2012 at 1:10 PM
    #247
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As mentioned, this does nothing. The electronics are already grounded to their own, isolated ground circiut. Running a "ground" wire from the throttle body, to any other place on the truck, simply gives you another wire under your hood. If anything, it would slow your truck down, as the added weight of the wire, is going to detract from performance on some level. You would get more of a gain by washing the dirt off your truck, or vacuuming out the cab.
  8. Aug 25, 2012 at 1:59 PM
    #248
    Shaunsquatch
    Shaunsquatch Well-Known Member
    Shaun
    Louisville, KY
    2020 Tundra
    I have no idea if grounding the TB helps or not, don't really care.
    I can come up with one possibility on why it might make a difference. With a floating(electrically) TB I could see electrical noise being generated on a position sensor, which could result in an incorrect or slowly filtered analog to digital conversion reading by the ECU. Grounding the TB would in effect shield the sensor and reduce noise on the sensor ADC lines and in effect reduce the feedback loop time between the position sensor and the butterfly.
    Its all speculation though as I have no idea if any sensors even exist inside the TB. I am not going to do it personally, but I could think of one possible effect and thought I would stir the pot.
