Grounding Throttlebody?
Discussion in 'Performance and Tuning' started by NC15TRD, Jun 6, 2011.
  1. Aug 25, 2012 at 1:36 PM
    #281
    whippersnapper02
    whippersnapper02 Well-Known Member
    Christian
    Yorba Linda, CA
    10 MGM TRD OR 4wd Auto DCSB
    Banks Monster Exhaust, Pop n Lock tailgate lock, Hook-Ups tie down brackets, USA Spec Ipod adaptor, WO seat covers, color matched grill with Grillcraft insert, Tuffy locking bed box
    How about grounding direct to ground with a steel cable dragging around under the truck?:D
  2. Aug 25, 2012 at 1:59 PM
    #282
    Shaunsquatch
    Shaunsquatch Well-Known Member
    Shaun
    Louisville, KY
    2012 DCSB TRD Sport
    I have no idea if grounding the TB helps or not, don't really care.
    I can come up with one possibility on why it might make a difference. With a floating(electrically) TB I could see electrical noise being generated on a position sensor, which could result in an incorrect or slowly filtered analog to digital conversion reading by the ECU. Grounding the TB would in effect shield the sensor and reduce noise on the sensor ADC lines and in effect reduce the feedback loop time between the position sensor and the butterfly.
    Its all speculation though as I have no idea if any sensors even exist inside the TB. I am not going to do it personally, but I could think of one possible effect and thought I would stir the pot.
