Grounding Throttlebody?
Discussion in 'Performance and Tuning' started by NC15TRD, Jun 6, 2011.
  1. Jun 12, 2011 at 8:31 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    lol yes. do it and post pictures!!!!
  2. Jun 12, 2011 at 8:35 AM
    rmb_crew
    :facepalm:
  3. Jun 12, 2011 at 8:46 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Post pics of the pics on your tv :D
    OP, I'm curious to see where exactly you grounded from you should show a pic. I read part of that Mazda grounding thread where the guy actually took an Ohms meter to the different components to test everything. Just thinking out loud here, but if its a smoother transmission that your ass is feeling, wouldn't it be better to place the ground on the tranny instead of the throttle body??
    Also, to the rest of you, don't be so quick to dismiss ass dynos. Though they aren't near as accurate, some of us spend over a 100km's a day behind the wheel. I know if my truck started behaving differently, even if ever so slightly, I would notice in a heartbeat.
  4. Jun 12, 2011 at 8:49 AM
    rmb_crew
    Also the information that was in the mazda forum doesnt sound right at all. in the post where the guy took a ohm meter to everything said he was reading 2 ohms on all 4 bolts but when he hooked up the ground strap he got 0.0 Well 0.0 means open which means its not grounded. so i dont know what kind of info he is putting out.
  5. Jun 12, 2011 at 8:51 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I'll be honest, i napped a lot during the electrical section of my process engineering degree. But i'm pretty sure ohms is the measurement of resistance, not flow of electricity. If your resistance is 0, that would mean a smoother, cleaner flow of electrons.
  6. Jun 12, 2011 at 8:53 AM
    rmb_crew
    correct but its impossible to have 0.0 ohms going through a wire. anytime you move electricity through anything you will have resistance. 0 resistance is like having an open circuit.
  7. Jun 12, 2011 at 8:57 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Super conductors have zero resistance, thats the whole point of them :) haha sorry i had to say it.
    Yea I know what your getting it, it's called transmission losses, aka the transferring of power losses power as heat. Power companies hate this law of physics cause they lose billions of dollars worth of power every year on transmission losses.
  8. Jun 12, 2011 at 8:59 AM
    rmb_crew
    lol u got a super conductor?
    I am a aviation electrician in the navy and deal with this stuff all day long.
  9. Jun 12, 2011 at 9:01 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    not impossible... :cool:
  10. Jun 12, 2011 at 9:02 AM
    rmb_crew
    lol ok in a tacoma it is impossible.
  11. Jun 12, 2011 at 9:02 AM
    Yoytoda
    Roland
    completely stock
    i work with superconductors all day long. 35 miles of 14 gauge wire with 0.00000000 ohms resistance
  12. Jun 12, 2011 at 9:04 AM
    rmb_crew
    yeah thats just ridiculous.
  13. Jun 12, 2011 at 9:04 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Looks like another cost cutting measure from Toyota.......bastards shorted us at least 10 HP! :rolleyes:
  14. Jun 12, 2011 at 9:05 AM
    Yoytoda
    Roland
    completely stock
    im dead serious...
  15. Jun 12, 2011 at 9:05 AM
    #35
    rmb_crew
    i dont doubt you at all. its just crazy that you can push power through a 35 mile long wire with no resistance just by a super conductor.
  16. Jun 12, 2011 at 9:08 AM
    #36
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Not off hand, but once I take over the world :spy:
    I suppose you could outfit your tacoma with an absolute zero refridgeration system. But the added weight would outweigh the benefits of the epic 10 hp ground wire :cool:
    I'm sure anything could help if you believe.
  17. Jun 12, 2011 at 9:09 AM
    #37
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Super conductors are gonna be the next big up and coming power tech.
  18. Jun 12, 2011 at 9:09 AM
    #38
    rmb_crew
    sooo where would you ground it to?
  19. Jun 12, 2011 at 9:09 AM
    #39
    rmb_crew
    like everything you gotta make it cost effective.
  20. Jun 12, 2011 at 9:11 AM
    #40
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    his ass?
