Grounding Throttlebody?
Discussion in 'Performance and Tuning' started by NC15TRD, Jun 6, 2011.
  1. Jun 12, 2011 at 9:12 AM
    #41
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    yup it needs to be super cooled with liquid helium. -452 degrees F.
    at -450 or colder niobium titanium has no resistance. So an MRI (what i work on) has 35 miles of wire charge to 500 amps to create a 1.5-3.0 Tesla field. But at 0 volts since voltage is measured as a difference. Without resistance there is no difference so its not only 0 resistance its only way to have current with no voltage
    btw. grounding the TB is bogus. Its bolted to the engine block which is grounded...
  2. Jun 12, 2011 at 9:13 AM
    #42
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    The is the big question, I bet i'll probably own the hydrid tacoma in ten years. power efficient :D
  3. Jun 12, 2011 at 9:15 AM
    #43
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Your an MRI technician? or you repair em? One of my best friends went into that field, she told me in case of an emergency with the machine, the helium purge costs 2 millions dollars if you push the big red button :eek:
  4. Jun 12, 2011 at 9:15 AM
    #44
    Yoytoda
    Roland
    completely stock
    too expensive. the wire itself is about $10 a foot and needs to be super cooled. SuperPower has been trying it for years. it will never be cost effective because niobium titanium is expensive and so is keeping liquid helium cold. the military had the company i worked for built gigantic superconductor capacitors as silent generators too. not cost effective. Thats why a 15 minute mri scan is 1200-1800
  5. Jun 12, 2011 at 9:19 AM
    #45
    Yoytoda
    Roland
    completely stock
    i repair them. Im a field service engineer magnet specialist. Used to work for Intermagnetics testing, building, and fixing them (we made all the MRI magnets for Philips). Then Philips bought Intermagnetic, worked there for 4 years. now i work for Aurora who uses philips/Intermagnetics magnets too
    Edit: The red button only costs about $150,000 worth of Liquid helium and labor to replace the burst disc, deice the magnet and re-ramping. Takes about 3 days to fix. Plus 3 days worth of lost revenue
  6. Jun 12, 2011 at 9:20 AM
    #46
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Nice! Thats a cool field to be in :D I love seeing cutting edge tech
  7. Jun 12, 2011 at 9:25 AM
    #47
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Hey, don't diss this. Some companies make a whole product line out of it :D, e.g. the HKS Circle Earth system:
  8. Jun 12, 2011 at 9:44 AM
    #48
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    You mean if I improve the ground on my CB antenna it will work better??!! NO WAY, you guys are crazy!
  9. Jun 12, 2011 at 10:08 AM
    #49
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Well, I'm going to go ahead and call out all of the self-proclaimed electricians on this forum who have yet to actually test the ground of the throttle body before making their claims.
    On my truck, my throttle body, as it sits from factory, has 340k ohms of resistance to ground.
    Now, wether or not .1 ohms would cause it to perform better is news to me, just saying. There's your data vs. speculation.
  10. Jun 12, 2011 at 10:23 AM
    #50
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    OP.. whats the conclusion?...Dying to do mine, but wanna know if its worth it.
  11. Jun 12, 2011 at 10:45 AM
    #51
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I just tried this. As far as it shifting smoother, I feel like I have vastly increased my psychosomatic shift-smoothness. I am going to leave it on for awhile and see what happens.
    As far as grounding improvement, you saw my post before. About 350k ohms to ground before, 0 ohms after.
  12. Jun 12, 2011 at 10:47 AM
    #52
    NC15TRD
    NC15TRD [OP] Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I have results in the OP, but here it is again: I didn't think I'd notice anything, but I figured I'd give it a go. Results were that while coasting at about 50mph (80.5kph for our Canadian friends) I pushed the accelerator fairly far down, enough to get the truck to shift to 3rd gear from 5th. It was real smooth with no hesitation of the truck trying to go in 5th or even 4th, just a real smooth shift to 3rd.
    That was all I noticed. So to see if I was crazy I took the wire back off and ran the same piece of road in the same manner and it hesitated to shift down. Try it if you don't believe me, I hardly believed it myself!
  13. Jun 12, 2011 at 10:48 AM
    #53
    NC15TRD
    Nick
    PA
    Thanks for backing me, it seems most wanna hate on someone trying something they haven't.
  14. Jun 12, 2011 at 10:53 AM
    #54
    jcremeans11
    jcremeans11 Well-Known Member
    Jon
    Ohio
    01 Tacoma SR5
    Spectre Cold Air Intake, Michelin XLT's (265/70/16), Escort Solo S3, Grounded Throttle body
  15. Jun 12, 2011 at 10:55 AM
    #55
    NC15TRD
    Nick
    PA
    Getting there!
  16. Jun 12, 2011 at 10:56 AM
    #56
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    Thank you:D
  17. Jun 12, 2011 at 10:57 AM
    #57
    JKD
    JKD Well-Known Member
    0.0 ohms really means "less than 0.05 ohms".
  18. Jun 12, 2011 at 11:06 AM
    #58
    jakedaugh
    jakedaugh GEAUX TIGERS!!!!
    JD275
    Louisiana
    '11 Magnetic Gray TRD Sport 4x4
    Bilstein 5100s at 2.5, skyjacker add a leaf, 16x8 Moto 951s, 265/75/16 Cooper STTs, 20% tint all around
    Is the throttle body spacer even worth it? I hear that its shit more than I hear that it works. So who to believe? lol
  19. Jun 12, 2011 at 11:10 AM
    #59
    jcremeans11
    Jon
    Ohio
    01 Tacoma SR5
    All I've heard are negative reviews from it, but those are mostly from people who were expecting 10 hp gains from it. I'm sure they gained a little better throttle response, but it's really not worth the money.
  20. Jun 12, 2011 at 11:11 AM
    #60
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Yes but you will still drool on your shirt.
