Grounding Throttlebody?
Discussion in 'Performance and Tuning' started by NC15TRD, Jun 6, 2011.
  1. Jun 12, 2011 at 8:54 PM
    #81
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    so i threw on some 16, went around the block, not sure yet... i'll re-do it with some 10 and test it out a bit more tomorrow or something
    but might have felt a little peppier
  2. Jun 12, 2011 at 8:54 PM
    #82
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    this sounds crazy but why not a try
  3. Jun 13, 2011 at 6:00 AM
    #83
    NC15TRD
    NC15TRD [OP] Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    How to in OP!
  4. Jun 13, 2011 at 6:51 AM
    #84
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    If you want to add some grounds go make your own kit. I have done this in the past on a few vehicles. Just get some 4 guage audio power wire and some gold plated grounding connectors. It should only cost you about $30-40 depending on how much wire you use. When I did my DIY grounding kit on my last vehicle. I had 3 Grounds: Body to transmission (replaced existing factory ground strap), Body to Alternator housing, and Body to Intake Manifold. Although I didn't notice any performance gains (NEVER TRUST YOUR BUTT DYNO, IT'S A FILTHY ROTTEN LIAR!) I did notice less dimming of my dash lights at night when under load (my stereo system turned up, and AC running)
  5. Jun 13, 2011 at 7:55 AM
    #85
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    still...any noticeable gains? $30 is a lot for a little peppier
  6. Jun 13, 2011 at 7:59 AM
    #86
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I bet you could do it for 10 dollars at canadian tire. I'm still on the fence, mostly because i simply dont have the time to try it. I'm curious to see the difference since i have the 6 spd manual
  7. Jun 13, 2011 at 8:04 AM
    #87
    NC15TRD
    Nick
    PA
    The only difference I noticed is the smoother shifting in my auto, I have no clue what it would do in a 6spd.
  8. Jun 13, 2011 at 8:06 AM
    #88
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I've got the V6 Auto, might give it a try if I get bored...
  9. Jun 13, 2011 at 8:12 AM
    #89
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Theres gotta be some correlation about freeing up some of the drain on the electrical power system, because the resistance on the TB is so high. I figure since the manual tranny uses less power then the automatic transmission. Might free me up even more power
  10. Jun 13, 2011 at 8:22 AM
    #90
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    soooo....of this debating back and forth, it seems that there has been many opinions on this matter going both ways...
    OP states smoother shifting in his auto
    No results yet from a manual yet?
    is this really a worth while mod? or did i just waste 5 minutes of my life reading through this thread?
  11. Jun 13, 2011 at 8:33 AM
    #91
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    What does a throttle body have to do with shifting since the TB has no gears?
    Maybe you should drill some holes in the butterfly valve to increase airflow. and ground your transmission while your at it.
    I just grounded my cell phone for gits and shiggles and woah! I got 4g instantly, on AT&T at that :D
  12. Jun 13, 2011 at 8:43 AM
    #92
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ^^^^ This I figure
  13. Jun 13, 2011 at 10:12 AM
    #93
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I dont understand how there is electrical resistance on the TB? a cable moves and the valve opens...
  14. Jun 13, 2011 at 10:15 AM
    #94
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i think all 05+ are fly by wire. IE you push the gas pedel down and it sends a electronic signal to the TB which opens and closes the valve. No more cable. I know my 09 has it but i dont know how far back it goes.
  15. Jun 13, 2011 at 10:17 AM
    #95
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :ohsnap:
  16. Jun 13, 2011 at 10:17 AM
    #96
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yup, electrical sensor system, not a real wire.
  17. Jun 13, 2011 at 10:19 AM
    #97
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    What is it in that uses the throttle body as a ground. If nothing uses it as a ground, i see no benefit to this.
    That being said, I may grab a piece of wire and do this if I'm bored later.
  18. Jun 13, 2011 at 10:20 AM
    #98
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    this is correct and if the motor wasnt grounded it wouldnt move at all. The motor still has an electrical ground. even though the throttle body has resistance, if you pull the connector to the throttle actuator it will have a proper ground with very little resistance. the motor gets grounded via the wiring harness not the throttle body so grounding the TB will not have any effect on the motor.
    when i say motor i mean the throttle servo motor.
  19. Jun 13, 2011 at 10:23 AM
    #99
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    If you ground your earlobes, you'll shit smoother.
  20. Jun 13, 2011 at 10:28 AM
    #100
    Yoytoda
    Roland
    completely stock
    just because there is resistance on the TB does not mean it will place a load on the electrical system. there is a lot of resistance from the rear of the frame to the battery. however, it is still a ground and a good ground at that. grounding does not mean that it has to have 0 resistance to the negative of the battery. A ground just has to be a common return path.
    also, if a load on the electrical system was noticeable there would be a performance difference when your lights are on or off. I doubt anyone can feel the difference from that.
