Grounding Throttlebody?
Discussion in 'Performance and Tuning' started by NC15TRD, Jun 6, 2011.
  1. Jun 13, 2011 at 1:08 PM
    #161
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i had to do the same damn thing. but i just stuck with the toyota filters.
  2. Jun 13, 2011 at 1:09 PM
    #162
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i just use my teeth
  3. Jun 13, 2011 at 1:10 PM
    #163
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    here is another serious theory. disconnect the plug to the tb. then check the resistance. Is the resistance infinite? then check voltage to the tb with the plug plugged in and no ground strap. if there is voltage there could be a reasoning that it is isolated. maybe, the resistance you are measuring is the motor source is shorted to the case for some reason and toyota designed the TB to be isolated so it doesnt matter. but if you ground it you could be grounding the voltage source and destroying the actuator motor and actually putting a load on the electrical system...
  4. Jun 13, 2011 at 1:10 PM
    #164
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I know folks talk about how much better the filter medium is in the OEM ones.
  5. Jun 13, 2011 at 1:12 PM
    #165
    Yoytoda
    Roland
    completely stock
    not that the medium is better but there is alot more of it. a while ago there was a test in popular mechanics and they said that the oil filters in toyotas filter down to something crazy like 1 micron with the same flow as a 3 micron filter
  6. Jun 13, 2011 at 1:13 PM
    #166
    rmb_crew
    colin i always knew you were crazy. but not that crazy!!!
    yeah that comparison that chris did was pretty cool
  7. Jun 13, 2011 at 1:20 PM
    #167
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the only downfall is when your ear touches the positive terminal and your right nipple touches the negative.....but you get used to it after a few oil changes. damn deep cycles pack a punch though
  8. Jun 13, 2011 at 1:21 PM
    #168
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    That's an interesting theory, however you can't check the voltage while the plug is connected to the TB, and once you disconnected you've deconstructed the circuit.
    Also, I don't think that toyota's choice of using plastic intake manifolds was because they wanted to isolate the metal TB.
  9. Jun 13, 2011 at 1:23 PM
    #169
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    That's better than a condom... :D
  10. Jun 13, 2011 at 1:23 PM
    #170
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    You can, you just have to backprobe the plug.
  11. Jun 13, 2011 at 1:24 PM
    #171
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    No worries, I've been neg repp'd for actually answering people's questions before
    not sure about the second half of what you said, but testing it with the harness plug disconnected is a good idea
  12. Jun 13, 2011 at 1:24 PM
    #172
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    It's insulated on the back though, or I would have tried that, I'd have to put something against the prongs as I plug it in or strip the wire back.
  13. Jun 13, 2011 at 1:25 PM
    #173
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    You can actually see the insulation on the back of the plug where the wire enters it on the picture I posted earlier, just FYI.
  14. Jun 13, 2011 at 1:27 PM
    #174
    macgyver
    Brad
    Canton, GA
    Push the probe through the insulation essentially parallel with the wire. I use sewing T-pins when I need to probe plugs.
    All this talk of probing makes me feel dirty... I need a shower.
  15. Jun 13, 2011 at 1:27 PM
    #175
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    My probe is too big :eek:
  16. Jun 13, 2011 at 1:29 PM
    #176
    macgyver
    Brad
    Canton, GA
    My spoon is too big.
  17. Jun 13, 2011 at 1:31 PM
    #177
    Yoytoda
    Roland
    completely stock
    i dont think so either.... its a suppppeeeeerrrr long shot as to any remote tiny explaination to why the ground would matter on the throttle body...
    you can check the voltage just by putting the positive of your meter to the tb and the negative to the battery or another ground to see if there is any stray voltage actually traveling to ground (of course you need to take the ground that you put on, off to test this). if there isnt any voltage that just proves my reasoning even more to why grounding the tb doesnt do anything
    EDIT: i forgot to say check the votage of the tb to ground with the truck running
  18. Jun 13, 2011 at 1:35 PM
    #178
    macgyver
    Brad
    Canton, GA
    You know what they say about big potatoes?
  19. Jun 13, 2011 at 1:36 PM
    #179
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  20. Jun 13, 2011 at 1:39 PM
    #180
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    0.003vdc with truck shut off (ref. point)
    0.027vdc with truck running.
