Group 35 DieHard Platinum/Odyssey PC1400, Battery Tray/Winch Control Mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dirty Pool, Feb 23, 2014.
  1. Feb 23, 2014 at 7:11 PM
    Dirty Pool
    Dirty Pool [OP] FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    This size battery only "kinda fits" in the OEM location. The terminals are correct but the stock hold down is just a little off and will not prevent lateral or twisting movement.
    Additionally I needed to have the winch control box mounted on the engine side of the battery. My dying Optima Orange Top had T-slots of sorts on each end that readily held the box along with a long hose clamp. All the cables were already cut and trained for this location so it had to remain.
    Old Optima and winch control, RIP after 12 years. Most folks say "they don't make em like they used to".
    Requirements for the new tray.
    It had to be non invasive/removable, prevent any possible movement of the battery and provide 100% support of the battery bottom along with providing a spot for the winch control.
    The solution was to mimic the way the OEM plastic tray was located. It has 2 nipples (white arrows, pic 3), so to speak, that fit into corresponding holes in the battery shelf on the fender. The new tray would end up as more of a box, preventing any sideways movement. The OEM hold down would be used for nothing more than to hold the battery down. I did add 3/4" x3/4" x1/8" angle with 1/8" rubber strips to the inside of the stock brackets on the hold down due to the new battery being not quite as deep.
    14g steel parts cut and bent, fresh from the acid bath (I hate mill scale).
    All welded up with 4 "heavy pattern" nuts tacked on for the control box mount and 2 short pieces of pipe on the bottom to "key" the tray to the fender shelf.
    All painted with a couple lengths of door edge trim to prevent any chafing of the battery case. The battery has lugs (pic above) at the base on the front and back eliminating any front to back movement. Thin rubber sheet was used between the box/battery and box/fender shelf.
    Installed with Mil. Spec. connectors.
    Now with dual quick disconnects.
    Wulf, unstpible, Jsainz99 and 4 others like this.
  2. Feb 23, 2014 at 7:36 PM
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    Very Very Nice!!!!!!!
  3. Feb 23, 2014 at 10:49 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Nicely done!
  4. Mar 23, 2014 at 8:40 PM
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    Nice. Very, very nice indeed. This is exactly what I am needing. Want to make another one? :D
  5. Jul 23, 2025 at 8:57 AM
    Glamisman
    Glamisman Well-Known Member
    I put a constant duty solinoid on the feed line from the battery to disconnect the power and control that with a relay. I had a winch many years ago that was direct wired and the contacts in the control box stuck durring a pull. Scarry as hell losing control of the pull.
  6. Jul 23, 2025 at 9:11 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Cool, that issue was the main reason for the quick disconnects. Takes a few seconds to do the "half turn" and you must be out of the cab but better than nothing.
    I wanted the control under the hood to prevent an ahole from "hot wiring" the winch with a paper clip. Haven't heard of it happening for quite a while but it once was a thing.
  7. Jul 23, 2025 at 11:35 AM
    Glamisman
    99% of my winching is moving things, trees, tree stumps, sheds etc. I always open the hood in case the cable or the purchase lets loose and I never use a chain, those things send shrapnel when they break. I was attempting to pull the trunk of a large Pepper tree last week and I had 4 X 6 blocks in front of each wheel and the winch just pulled the truck over the blocks, I over winch my vehicles, I figure for a few dollars more, why not.
