GROUP BUY:Built Right UCA's
Discussion in 'Group Buys' started by be.original, Apr 13, 2015.
  1. Apr 16, 2015 at 7:58 PM
    be.original
    be.original [OP] Active Member
    Absolutely, some even run ball joint UCA's on spidle lifts. According to maxtrac you can use stock control arms?
    Copied from site:
    Maxtrac Suspension's lifted spindles are a simple, but extremely effective way of gaining additional clearance in the front of your vehicle for larger wheel and tire setups. By simply replacing your stock spindle which is known to bend under extreme circumstances, you can achieve an additional 4", while using the stock control arms and coilovers. Maxtrac's spindles are made from Ductile Iron, and are designed to be 100% bolt on, with extreme durability. You may utilize the stock sway bar with these spindles, along with the factory ABS lines, but extended brake lines are required.
  2. Apr 17, 2015 at 3:46 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    If your leveling you shouldn't need it. Lots of guys here went 2.5 front and still used stock UCA. I'm going back to. 85 +1.6 eibachs and I plan to run stock UCAS so I hope it works
  3. Apr 17, 2015 at 4:51 AM
    be.original
    This is a sensitive topic. Most would agree that under 3" aftermarket UCA's are not needed. If you do run them under 3" either you plan to go higher in the future or you have money to blow. I currently am at 3" with stock UCA's, my caster is off and my truck darts at highway speeds. I would say hold off on the UCA until you put the lift on, and if you absolutely feel the need for them....then get them.
  4. Apr 17, 2015 at 8:56 AM
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    Yep, our (Colorado TW section) long time wheeler and actual Toyota Techie says UCA's are not needed 3" or under, "but it will steer better" with aftermarket UCA's.
    So, I am lifting and than wait and see, next tax return for sure will get replacement UCA's
  5. Apr 17, 2015 at 9:24 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Personally I wouldn't get them if I could do it again
  6. Apr 17, 2015 at 12:20 PM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    They look less stock than the LRs :D.
  7. Apr 18, 2015 at 10:56 AM
    Lpheat22
    Lpheat22 Well-Known Member
    Albert
    La Puente, SGV
    09 PreRunner SR5 DCSB Sport
    DDM Tuning 6000k HID Headlights, Pioneer X5500BHS, CSJumper switchbacks, Fox 2.5 w/reservoirs and CDC adjusters, Sick Nick PreRunner Tube Bumper, 17 in SCS Stealth 6's Matte Gunmetal, Toyo ATII 285/70/17
    I'm in on these
  8. Apr 18, 2015 at 12:24 PM
    be.original
    Added to the list, thank you
  9. Apr 18, 2015 at 12:38 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    so what are the advantages of a uniball design versus a design like LR?
  10. Apr 18, 2015 at 1:47 PM
    be.original
    Ball joint vs uniball.
    The LR's are constructed using OEM style ball joints which limit movement and articulation. The LR's still although allow for caster correction and if used mainly on road require less maintenance. If you wheel moderately or hard these may wear out quick.
    The built right uca's use a 1" stainless steel uniball allowing for greater articulation. Some uniball uca's are also known to have a wider range of caster correction,few not all. These so require mainenance and checking, usually done after an oil change or harsh offroading. They will last long if cared for.
    Edit: even though the new LR's have proven to be solid the old reputation steers me away from them
  11. Apr 18, 2015 at 4:08 PM
    lanning
    lanning Well-Known Member
    Chattanooga TN
    2008 DCLB
    So is the limit 15 sets or is the 30th of April the end of the group buy. It reads both ways in the original post. Sorry if I am just reading it wrong.
  12. Apr 18, 2015 at 4:22 PM
    be.original
    Sorry for the confusion, ideally whichever comes first which is looking like 15 people. It will take 2-3 days to confirm and verify shipping and payment details. More members may join the list during that 2-3 day window.
  13. Apr 19, 2015 at 6:44 AM
    be.original
  14. Apr 19, 2015 at 7:09 AM
    Adamw1988
    Adamw1988 Well-Known Member
    Adam
    West Tennessee
    2015 Trd sport
    I am interested. Checking on funds.
  15. Apr 19, 2015 at 3:30 PM
    #35
    Aueehonda
    Aueehonda Member
    Jay
    Alabama
    13 trd sport dcsb 4x4
    2" AAL, billy 5100's set at 1.75" on front, body armor rear bumper
    Will these improve clearance over stock UCA's much? I'm looking to go with 255/80r17 tires on stock sport wheels and was thinking they may hit my stock UCA's. I'd so I'll prob get into the group buy. Thanks
  16. Apr 19, 2015 at 4:05 PM
    #36
    be.original
    Without details I couldnt say. They may not stick out as far, but without wheel spacers or positive backspacing on your wheels they may still hit. I think you mean 255/75r17? I needed to put 1.25 spacers on my truck to clear the OEM UCA's
  17. Apr 19, 2015 at 10:27 PM
    #37
    Relimb11
    Relimb11 Active Member
    2014 TRD sport
    Snugtop sl tonneau,afe pro dry s filter,trd exhaust,pro comp 5001 rims,duratracs 285/75/16,wet okole seat covers,led map lights,Bilstein 6112's,built right uca,icon aal,icon 2.0,raptor grill,cmc
    I want in on the list:D
  18. Apr 20, 2015 at 5:22 AM
    #38
    be.original
    Added, thank you
  19. Apr 20, 2015 at 5:47 AM
    #39
    be.original
    2 more commited buyers and we can start the ordering process
  20. Apr 20, 2015 at 10:54 AM
    #40
    be.original
    guys,
    ordering will start soon. PM's sent to all on the list. It does not hurt to add more members during the ordering window (4-5 days). Detailed instructions for payment, ordering and shipping will be listed in the first post in bold and red on the bottom.
