Cam gears for V6. Add power AND mpg
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mightytacoman, Jul 7, 2019.
  1. Jul 7, 2019 at 5:26 PM
    mightytacoman
    mightytacoman [OP] Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Want more power, better gas mileage, and improved reliability? Read on.
    Currently not making these.
    U R D is finally selling these at a fair price (currently listed at $115.) So I'll let him have the business so long as his prices remain fair.
    I'm still active on this forum and willing to help anyone with questions on these as needed.
    link to his product here: https://urdusa.com/urd-exhaust-cam-gears-4-0l-v6/
    Bonus: add coupon code forummember for an additional discount on his products.
    More usable power, better gas mileage, and increase the reliability of your truck? Sounds impossible I know. Intakes and exhaust are cool n easy to do and all but if you're willing to dive a little deeper- you'll find these work better than both even when you combine the other 2. If you're an engine novice I assure you this isn't impossible but does take about 4 hours to do- I do my best to be available whenever anyone has questions and have walked many people through the install.
    These are NOT snake oil or some gimmick. Many here have tried these over the years now (I've sold hundreds). Read some of the reviews and posts here if you're still hesitant. Not a single negative post yet.
    So what I do is I take a brand new toyota cam gear and machine a 2nd keyway into it that's retarded 3°. Simply pull your stock exhaust cam gear out. Install these gears using the new keyway that retards the cam and reassemble.
    These work with all the 1GRFE single VVTi (V6) engines. 2005-15 Tacoma, 03-09 4Runner, 07-09 FJ Cruiser, and the 05-09 Tundra as well as many other vehicles found in foreign markets.
    Tuning to maximize the gains associated with this mod is recommended but not necessary. (just like an intake, exhaust or other performance part)
    What exactly do these do?
    "The exhaust cam gears retard the exhaust gear timing by 3° in relation to crank angle. Allowing the cylinders to empty more completely on the exhaust stroke. On the intake stroke the cylinders will fill with more air and fuel increasing the overall volumetric efficiency of the engine. There will also be less hot exhaust gas left heating the incoming air and fuel and reducing it's knock potential. This is very advantageous with forced induction conversions." -URD
    Myself and many others are now running these gears with great success (with and without superchargers). It increased my mileage and has notably more power in the low to mid rpm range. Plus the engine just runs happier and idles smoother. Before and after datalogs shows an increase in knock threshold (tables proving this are located on a page 2)
    Big thanks to @nd4spdbh for doing a before and after of his MAF numbers with no other changes made at the time. About a 5% measured increase across the rpm range. MAF numbers are proven to directly relate to actual Horsepower (MAF in g/s * 1.18 = ~HP for our engines)
    Orange line = after install of 3* cam gears
    Blue line = stock cam gears
    Bottom axis = engine rpms
    Left axis = MAF reading in lbs/hr
    Here is an install video.
    https://youtu.be/YmwXtpukhFU
    Another link to Gio's awesome video taking this step by step.
    https://youtu.be/xNV_3Iy56tY
    Here is a link for valve cover removal instructions. (Pre 2012 models)
    http://www.toyota120.com/forum/showthread.php?p=186857
    here is the pdf install instructions from URD
    https://www.tacomaworld.com/attachments/urd-1gr-cam-gear-installation-v-1-1-draft-pdf.3283622/
    THIS GEAR IS UPSIDE DOWN. You want the timing dot to be at the bottom
    "F" for front. Gears sent out willl have this "F" . I recommend drawing with a marker or whiteout etc. a line to the tooth that is most closely aligns to (this line is drawn for you starting with GB4.) (GB16 onward- the "F" is removed and only the line is drawn)
    PAINT WORN OFF AND YOU CANT TELL WHICH WAY IS CORRECT?
    Looking at the gear with the timing dot at the bottom (machined keyway upward)
    The machined keyway should be slightly to the left of the tooth it most closely points too. If it is slightly to the right than you have the gear flipped and install would lead to a 3° advance instead of the desired 3° retard.
    Here is the stock gear with the keyway facing up (yellow arrows). If you look closely at the chain itself, you can see a link on the backside that is painted orange from the factory (under blue arrow). The orange chain link is from the factory and wont align perfectly with the keyway with every turn of the crank so you might have to turn the engine over by hand via the crank pulley a few times to get this orientation. Once in this orientation, the chain is already marked for you for which link the newly marked keyway/tooth will go into.
    Update 3/19/21
    In order to get the smaller chains to line up "perfectly" it takes 18 revolutions of the cam gear per perfect line up. (That's 36 crank rotations) Getting all 3 chains to line up took me 108 cam gear revolutions. It could take even more as it wasn't perfect when I started counting on the engine I was working on.
    Here is the re-machined gear installed. 2nd bevel not visible so its in correct orientation. You can see that the new keyway and its closet aligned tooth is right back in on the orange link (marked in red here) After you get this done on both engine banks- you're done and can start re-assembly.
    Gear installed correctly here (driver side). Notice the timing dot is NOT in the keyway but opposite.
    Correct install passenger side. Note the yellow link is in the front and not in the back like normal. This is my fully built engine and I turned the chain around to better illustrate proper timing.
    Another angle that shows timing better.
    Including some nice pictures of proper timing. Note where and how each cam is pointed. This is perfect timing for TDC driver side
    perfect timing driver side at TDC
    Perfect timing at TDC passenger side. This pic also shows where gasket sealer goes. It is about a 1 inch strip where the heads meet the front cover. you need two 1" strips per side. 4 strips of the gasket sealer total for the engine.
    Shout out to @Gilmorec61 for some great photos he took during his install :cheers:
    Replacement Gasket part numbers:
    • Right (passenger) Valve cover gasket - 11213-AD010
    • Left (driver) Valve cover gasket - 11214-AD010
    • Surge tank upper to lower intake gasket - 2005-11 17176-0P010 for 2012+ 17176-0P030
    • Throttle Body Gasket - 22271-0P010
    • For 2012+ with SAIS . The gaskets for the tubes onto the valve assembly are 17377-31010. You'll need 2
    Torque values:
    • Cam Bolts - 74 ftlb
    • No.2/3 Chain Tensioner Assembly bolt - 14 ftlb
    • Valve Cover (per side)
      • Outer Bolts (7x short) - 7.4 ftlb (88.8 inlb)
      • Outer Nuts (2x) - 80 inlb
      • Inner bolts (3x long) - 80 inlb.. rubber bolt gromet on these is part# 90210-06013 (3 per valve cover) (I re-use old ones)
    • Coil Pack bolts - 7.4 ftlb (88.8 inlb)
    • Surge tank (aka Upper intake) to lower intake (2 nuts, 4 bolts) - 21 ftlb
    • Surge tank stays / throttle body bracket bolts - 15 ftlb
    • Throttle body bolts - 9 ftlb
    Optional Stuffs:
    • PCV Valve - 20 ftlb - OEM part# 12204-31030
    • Toyota recommends their overpriced gasket sealer (fipg) I recommend the permatex ultra black gasket maker. It goes on as a ~1" strip where the valve cover meets the front cover for extra sealing protection.
    Video I shot of perfect timing.
    Note-my secondary chains have been flipped so colored links face forward when I had the engine on the stand.
    https://youtu.be/HEvgPpmnndc
    different pdf link for urd install instructions ↓↓↓↓
  2. Jul 7, 2019 at 6:56 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Bump. +1 rep
  3. Jul 7, 2019 at 6:58 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    +1
    Solid work, fast turn around.
  4. Jul 7, 2019 at 7:25 PM
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Loving mine, crazy fast work too.
  5. Jul 7, 2019 at 7:31 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    +1 can't wait to receive mine. Be mindful when ordering your own gears, it will take time. It seems we've exhausted some sources of gears from different vendors already with just our small run of 30 orders.
    mightytacoman[OP] likes this.
  6. Jul 8, 2019 at 6:25 AM
    dark vader trd pro
    dark vader trd pro Well-Known Member
    William
    NY
    2015 Tacoma Trd Pro
  7. Jul 8, 2019 at 7:27 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Awesome product, excellent customer service, fast turnaround! Thanks Kelby!
  8. Jul 8, 2019 at 1:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  9. Jul 8, 2019 at 4:59 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  10. Jul 11, 2019 at 1:36 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Awesome job, GLWS Kelby :cheers:
    Thuguon2.7 and mightytacoman[OP] like this.
  11. Jul 15, 2019 at 4:20 PM
    mightytacoman
    Kel
    4.5L 1grfe
  12. Jul 15, 2019 at 6:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Daaaaaaaaaayum! Going to help a friend install his set.
  13. Jul 15, 2019 at 6:41 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Can I be said friend.:thumbsup:
  14. Jul 15, 2019 at 6:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Teleport you and your truck. ;)
  15. Jul 15, 2019 at 6:43 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I need a Camry with a good tow package.
  16. Jul 15, 2019 at 6:49 PM
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    Just received mine today. Awesome product and service. Thank you sir!
  17. Jul 17, 2019 at 1:10 AM
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Any dyno testing to see what kind of numbers these things will add? Seems like a cool product.
  18. Jul 17, 2019 at 3:51 AM
    mightytacoman
    Kel
    4.5L 1grfe
    A cam gear only before and after dyno test has never been performed to my knowledge. @Torspd have you seen or heard if its been done? Urd has them in the kits they sell and they have full bolt (including these) dynos vs before numbers. Only numbers I can speak to are improved gas mileage, improved "butt dyno" and better driveability.
    Don5352 and Torspd like this.
  19. Jul 17, 2019 at 5:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You also have a datalog of better knock threshold. Which allows more timing. Which makes more HP.
    There are no dyno's yet, with just a cam gear install. Only your datalogs.
  20. Jul 17, 2019 at 6:29 AM
    Tacolover07
    Tacolover07 Well-Known Member
    German
    11 DCSB sport
    Leveling kit, 33’s, new headlamps,
    Is this for any year Tacoma? I have a 2011 dcsb 4x4 w leveling kit and 33’s and looking for that “stock” power feel again. The better mpg’s is a definite plus.
