++ Group Buy: Dirt Designs *2nd or 1st Gen* Shock Bucket Top Engine Crossover Bracket ++
Discussion in 'Automotive Group Buys' started by SconnieHailer, Dec 1, 2015.
  1. Dec 1, 2015 at 6:50 PM
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Long title, but its a bit of an "out of the ordinary" part. This group buy is for a shock bucket top component of an engine cross over strut system. @dirt designs has been cool enough to offer us a group buy on this part.
    1. What is this part?
    - It mounts to the top of your coil bucket and provides a mounting point for a 1.75" OD tube (.120 wall for moderate beating and thicker if you like) to act as a coil bucket brace. It will help prevent the coil buckets/frame from bending under heavy use/FUN!
    - Also, this part allows you to bend up your own secondary shock mount tube and sleeve it into the provision built into the bucket top.
    2. What is involved in installing this part?
    - You will have to source your own tubing and bender to get the cross over bent for your truck. There is NOT a crossover tube included in this because every truck is different.
    3. What are the order options?
    -Parts delivered as Weld It Yourself ($100) ($80 if we get 5+ in the GB)
    -Parts delivered as welded component ready for install. ($160) ($128 if we get 5+ in GB)
    4. Shipping?
    -Prices don't include shipping. Invoice from Dirt Designs will include shipping costs. For me, WY from CA it's roughly $20.
    5. Will these fit 1st Gens??
    - See page three for pictures and if you want version one or two.
    Pictures:
    These are installed photos from @jjhitchen truck. Bypass provision is not installed in these. As you can see you will have to cut a bit of your fender out
    Stryker420 likes this.
  2. Dec 1, 2015 at 7:20 PM
    SconnieHailer
    Marc
  3. Dec 1, 2015 at 7:26 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    What kind of hardware is used to mount this? It looks like it has a small nut and washer, do I just find a bolt that will thread through my Icons and attach a lock nut to the other side?
  4. Dec 1, 2015 at 7:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    IDGAF if I have to cut a lot of fender out. Hope this fits 1st gens
  5. Dec 1, 2015 at 7:30 PM
    SconnieHailer
    Marc
    Good question. I planned on making a hardware run to get a longer bolt to bolt the bracket to the coil bucket top. I'm guessing the washers you can see on joels rig are there to fit the top of the coil bucket which has a small part formed up in the middle.
  6. Dec 1, 2015 at 7:32 PM
    SconnieHailer
    Marc
    Haha, Frank could use some more cutouts!
  7. Dec 1, 2015 at 7:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty much haha
  8. Dec 1, 2015 at 7:35 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Sweet! Thanks for getting this together Marc! So does GB pricing apply for 5 total kits, either welded or not, or do we need 5 welded, 5 WIY for the discount?
    As you know, I am interested in the WIY.
  9. Dec 1, 2015 at 7:38 PM
    SconnieHailer
    Marc
    I assume it's for 5+ either way @Wishbone Runner . Steve (aka dirt designs) said he hardly gets on here (TW) so any direct questions that I cannot answer just email him at socalmoto@gmail.com
  10. Dec 1, 2015 at 7:40 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Cool, that would make the most sense, I'll hit him up!
  11. Dec 1, 2015 at 7:44 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    They should bolt through the new piece and then thread into the coilover top hat. In the pic you are referencing, I think it is on an LT kit with a different top hat that uses nuts and bolts.
  12. Dec 1, 2015 at 7:47 PM
    Sje1124
    Sean
    Louisiana
    Just a few
    Ok, the little bolts that came with my Icons don't look like it has enough thread the add the new mount. I'd be kid of hesitant to run them with out a longer bolt. I'll post a picture in a few of how mine look now.
    Stryker420 and SconnieHailer[OP] like this.
  13. Dec 1, 2015 at 7:47 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Awesome thank marc. Ill get an email out soon
  14. Dec 1, 2015 at 7:49 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, they will Probably will need longer bolts, easy fix.
    SconnieHailer[OP] likes this.
  15. Dec 1, 2015 at 7:57 PM
    dirt designs
    dirt designs Well-Known Member
    slo
    01 Tacoma race truck
    Only factory parts left is cab and frame rails
    Thanks Mark!
    On the kits I build for tacomas they use through bolts on the shock adapter plate. To use these mounts you will need bolts that are about 1/4" longer. Standard bolts I run through are 3/8" gr8
    This does not fit the 1st gens, but it just so happens I also have mounts for those. 5+ orders on those and I can also do 20% off, same pricing. Instead of a tube end with single 1/2" bolt, the 1st gen use a plate flange that you weld the engine crossover tube to.
    Discount on wiy or welded. As long as were on a run of the same parts its quicker setup time and building so you guys save money.
    AR15xAR10 and SconnieHailer[OP] like this.
  16. Dec 1, 2015 at 8:08 PM
    SconnieHailer
    Marc
  17. Dec 1, 2015 at 8:12 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Fantastic, email sent, thanks!
  18. Dec 1, 2015 at 8:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This looks interesting. Not sure if I need it tho.
    It'd be cool to see more pics of the 1st gen setup. Particularly, where the cross brace goes thru the fenders. Both sides are already pretty crowded in those spots.
  19. Dec 1, 2015 at 8:42 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    On the 2nd gens is there a reason for not cutting hole large enough to fit the top hat mount to weld the tube end to the tube in the mount and weld that to the mount (elminating the need for the 1/2" bolt)?
    From my undestanding was that shock tower crossover tube should be solid therefore they dont pivot. Maybe its a dumb question, i just know back in my car days you wanted something like this with no pivot bolts in the crossover mounting:
    Not this:
    nudavinci64 and angeldavid216 like this.
  20. Dec 1, 2015 at 8:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweeeeeett. So we need 5 1st gens too for the discount?
