GROUP BUY: LED Light Pods and Bars, 2" Square to 50" Dual Row
Discussion in 'Group Buys' started by JasperOffroad, Jan 20, 2013.
Thread Status:
Not open for further replies.
  1. Feb 3, 2013 at 5:04 PM
    #161
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    yessur! i've considered swapping out the cheap internal ballasts for OEM stuff but that's a whole 'nother thread.
    yeah when going camping my friends are notorious for waiting until dark to fully set up camp. the more light in the rear, the better. nothing at all wrong with the HIDs but as you said the charge time gets annoying. i'll now have to think about those but will prob go with 2 6" doubles because they are cheaper and i don't exactly need to go all out back there :D thanks! i'll put my order in sometime in the next few weeks.
  2. Feb 4, 2013 at 2:34 PM
    #162
    bkmcinty
    bkmcinty Well-Known Member
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    3" pods came in today.....look good so far will post pics tonight of night shots
  3. Feb 4, 2013 at 5:22 PM
    #163
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Finally got the bar mounted, and the truck washed. Part 2 of my review.
    The 30” bar was a little bigger than I expected. When I read 30” id assume the outside dimensions would be 30” inches. Thats not the case and it made fitment a little difficult where I wanted it. I do not know if this is the same with all manufactures, or if they’re going by the inside dimension of the light. I was unable to retain the old light bar(Although it was only for cosmetic appearance) and custom brackets had to be made.
    Overall width: 31 ⅜”
    Height: 2 ⅞
    Depth: 3 ⅜
    Bracket:
    Height - 3 ¼
    Height to hole - 2 ⅞
    Width - 1 ¾
    For my brackets, I went with ⅛” scrap steel I had from another project. Re-used my old light bar holes and it fit pretty well. Had to do some tweaking to squeeze the bar between the mounts, as when they were vertical they were narrower than the bar. Ended up with a sort of V shaped bracket for my specific install.
    The cord was the perfect length for my install(3 ft). I didn't have to trim or extend it, depending on where you want to mount this it may be short. Keep that in mind. I re-used my switch and relay from my Hella 700 hid conversions so I only had to do minimal wiring. I ran the cord through my grill and connected it to my existing wires near the driver side headlight.
    After going through the pictures I noticed the bars ends looked twisted. I thought it might be an illusion from the camera, but after looking at the light... it was. It was easy to figure out why... while tightening the bolts it appears to twist the bar slightly. I had to hold the light steady while I tightened. This could be from the extruded aluminum body being too thin, or just because its so long. Im not positive but I dont see it being a problem.
    And the part everyones been waiting for... light output. I took pictures on 2 different nights with the same camera settings. I wanted to compare my HID’s to this bar as well as my headlights. The HID’s imo are great pencil beams. But around here we have a lot of curvy roads and a 5’ circle on the tree’s in front of you sucks. The light bar does an AWESOME job at distance and flood light. On the back roads it lights up the sides as well as further down. Perfect IMO.
    And mounted pics. Enjoy! Let me know if you have any questions.
  4. Feb 4, 2013 at 5:51 PM
    #164
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    So I tested the three inch pods and I think I got sent flood instead of spot which I ordered I can't quite tell as they through light everywhere. They are half as bright as my roommates 6" round led light which has 12 LEDs in it but rated at 750 lumens and the 3" pods are rated at 1200 lumens.....so I'm not too excited about that but I will be using them as fogs anyways so they don't have to be super bright. But these lights are either way overrated as far as lumen output or the other lights I compared them to are way underrated. This could have to do with me getting the flood light version vs the spot but once again I'm not sure it's not listed on the light.....I will say these lights are very well built and compact. I will probably get a few more just to use as auxiliary lights in the rear or sides of my truck. Can't wait to get the 6" bars to compare them to
  5. Feb 4, 2013 at 6:13 PM
    #165
    obzerver
    obzerver Well-Known Member
    Justin
    Surrey, BC
    09 SR5 TRD
    Grillcraft grill, 20" LED Light bar, 17" MB TKO wheels, 265/70R17 Cooper ATPs, Uniden PRO520XL CB, Pioneer AVH-P2400BT
    Thanks for posting this. You just answered all the questions I was about to ask. I have a set of the Hella 500's with HIDs and was curious to see the difference between them and the light bars.
  6. Feb 4, 2013 at 6:46 PM
    #166
    JasperOffroad
    JasperOffroad [OP] Well-Known Member
    What is the wattage of your friends 6"? The 3" pod lights are rated in actual "out-the-front" lumens as measured in an integrating sphere both at the production factory and by an independent US based testing lab.
    The best way to tell if unsure is that the spot will have a smooth reflector. Flood will be ridged inside. See attached photos.
    You are welcome to send them back for a full refund.
    I have literally sold hundreds of the 3" pods and this is the first comment I have heard about them not being bright. I have received more than I can count stating the opposite.
  7. Feb 4, 2013 at 7:03 PM
    #167
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Mine are flood for sure and now it makes sense why his spots are brighter than my floods at a distance......whew I was starting to get worried for a second. Build quality is great though
  8. Feb 4, 2013 at 7:05 PM
    #168
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    You have an email sir
  9. Feb 4, 2013 at 7:08 PM
    #169
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Here is the light next to my STOCK headlight......and it's a flood pod so I'm doing it a favor by shining it so close to my garage door
  10. Feb 4, 2013 at 7:09 PM
    #170
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Stock headlight
  11. Feb 4, 2013 at 7:10 PM
    #171
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Just the 3" pod FLOOD
  12. Feb 4, 2013 at 7:36 PM
    #172
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    good looking pics!
  13. Feb 4, 2013 at 8:07 PM
    #173
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    How long does this offer stand? I have to buy a helmet light but after I buy it I want to invest in a 12 or 20" light bar.
  14. Feb 5, 2013 at 8:00 AM
    #174
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Guess I covered everyone's questions?
  15. Feb 5, 2013 at 8:03 AM
    #175
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    All in all you recommend it? i want the 20" lol
  16. Feb 5, 2013 at 8:04 AM
    #176
    bkmcinty
    Fort Myers, FL
    08 PreRunner SR5
    Black Badges
    Obviously you do t have a stock bumper but how do you think that 30" would look in my lower valence? I have a satoshi grill mesh in there now but that would come out and be replaced by the light.....not sure if that would be too low or not? Thoughts?
  17. Feb 5, 2013 at 8:05 AM
    #177
    PLC721
    Patrick
    Chandler, Az
    it would look awesome
  18. Feb 5, 2013 at 8:09 AM
    #178
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Yes I do. Has a year warranty so reliability shouldn't be a problem.
  19. Feb 5, 2013 at 8:34 AM
    #179
    PLC721
    Patrick
    Chandler, Az
    sweet good to hear, i think ill pull the trigger. Would it ship out today?
    Also im replacing HID Kragens and need some distance, should i get the full spot?
  20. Feb 5, 2013 at 9:05 AM
    #180
    Jared
    Jared A Bad Ass Member
    Jared
    Porterville, Ca
    2011 Toyota Tacoma DCAB LBED 4WD
    Current Mods: -Viper Alarm System -Covered up seat belt buzzer -WeatherTech Floor Mats -Fog lights turn on with Bright Lights -17 inch Chrome Tacoma rims (off a 2012) -Line-x'd the front skid plate -USB charger that plays music via Mediabridge -Window Tint: Front-20%, Back-5% -Front Toyota License plate logo -2 Extra D Rings in front -Bright Reverse Light Bulbs -6,000K Head light bulb -6,000K Fog light bulb -LED Dome & MAP light bulbs -Trailer brake controller -Escort 9500 Radar Detector (hardwired) -BendMount Mirror Radar mount -C.B. Radio with a built in Mic Plug in by Aux -LED Bed lights with an extra fog light switch -30 inch LED light bar under front grill wired to an extra fog light switch
    Definetly interested in the6 inch light pod. Where do they ship from?
Thread Status:
