Group Buy Swappable SC pullies and Custom TRD boost/vac AFR Gauges
Discussion in 'Performance and Tuning' started by bass mechanic, Mar 13, 2013.
  1. Mar 13, 2013 at 12:03 PM
    bass mechanic
    bass mechanic [OP] Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    Hey fellas, I am putting together a group buy for a solution to allow us to change pullies easily.
    I have a very reputable company who already has pullies that will fit the 4.0l TRD SC.
    they make a hub assembly that will fit on the shaft and allows with 5 screws to swap the pully in about 5 minutes with just a simple allen wrench!
    they make pullies ranging from 2.2", 2.3", 2.4", 2.5", 2.6", 2.7", 2.8", 2.9", 3.0"
    not sure exactly what sizes will be available yet. but the good news is we are in process of looking to see if one of their current pullies will fit with the correct offset, if not they are willing to make some for our application.
    but as of now it looks like the hub will already fit, just need to make the pullies with a slight change for this application.
    of course youll still have to machine the snout of the SC and URD makes a great tool for this.
    the best part is the pullies are only about $80 bucks each and you can pick any size you like. you only need to install the hub 1 time and swaps are easy as pie!
    additionally I am working with another company who makes a BOOST/VAC gauge that we can have custom made with the TRD logo, illuminated to match the dashlights of your truck! they can do any color you like even if you have swapped out the LED'S for a different color.
    they also have an ANALOG wideband AFR gauge that will match. it uses the AEM inline UEGO sensor and AEM Bosh o2 sensor for extreemly high accuracy.
    ill have a picture of the gauges soon as they are currently in the art department being drawn up.
    another great feature of the gauges is their illumination setup will work with the funky dash illumination of the tacoma, for thoes of you who have had problems getting the gauges to dim with the dash lights this will totally solve that problem.
    the gauges all have quality electronic stepper motors and are totally electronic. their boost gauge also references the current barametric pressure so they reading is accurate at any elevation. most gauges use a MAP sensor which will give you accurate and absolute readings. personally I prefer to see the gauge pressure or actual boost above my density altitude pressure.
    the gauge faces will be the same font and design as the factory look.
    the best part is the gauges are very affordable compared to some other brands. (ill have prices later)
    right now I am just trying to gauge some interest to see how many would be willing to buy in to the pullies and or the gauges.
    I think if I can get 10-15 people willing to perticipate we can all get a healthy discount.
    so let me know here who is in, this will not be a long wait either because both companies make nearly the exact parts we need already, the gauges maybe a week or so from when we place the order and the pullies maybe 2 weeks.
    you can PM me if you like but ill need to clean out my Pm box frequently or you can message me on AIM
  2. Mar 13, 2013 at 1:51 PM
    1strongone1
    1strongone1 Well-Known Member
    Jeff
    Iowa
    12 TRD Sport Supercharged
    Lifted, 33's, Supercharged, Volant Ram air CAI, Walbro fuel pump, 2.85 pulley, TRD exhaust, Bully Dog GT-T
    I would like a boost gauge, especially if I could get a pillar mount with it.
  3. Mar 13, 2013 at 2:01 PM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Wow I couldn't imagine the TRD supercharger having a 2.2" pulley!! that would be insane and might do more harm then good lol
    A boost gauge might worth looking into my near future
  4. Mar 13, 2013 at 9:41 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Pictures of these pulleys and hub application would definitely provide more attention;) Interesting nontheless...
  5. Mar 16, 2013 at 3:33 AM
    B3AS7808
    B3AS7808 Well-Known Member
    San Diego, CA
    13 DCSB 4.0 4x4
    TRD S/C,URD 2.8 Stealth pulley, DTLT Headers,URD ypipe, URD rear O2 Sims, TRD catback, Powerstop rotors and pads, weathertech floor liners. RCD 4.5 lift. Nitto Trails 295/70R/17, KMC XD125's.
    i am interested in pulley and gauges.
  6. Apr 29, 2013 at 10:51 AM
    fnkytrd
    fnkytrd Member
    05 Tacoma 4x4 TRDcharged
    Got a trd boost gauge. Would be interested in the afr guage and pulleys.
  7. Apr 30, 2013 at 5:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is a very interesting post. Sub'd for knowledge.
  8. Apr 30, 2013 at 6:03 AM
    bass mechanic
    none
    well now that this thread is gaining some momentum ill get back on the band wagon and get you guys some pictures of the finished product.
  9. Apr 30, 2013 at 8:17 PM
    B3AS7808
    San Diego, CA
    13 DCSB 4.0 4x4
    cant wait!
