** Group Buy ** Warrior Products - Bed Channel Accessories!
Discussion in 'Automotive Group Buys' started by WarriorProducts, Oct 5, 2017.
  1. Oct 5, 2017 at 4:11 PM
    WarriorProducts
    WarriorProducts [OP] Well-Known Member
    WarriorProducts
    2011 Toyota Tacoma / Blue
    Total Chaos Suspension, Fox Shocks, 3" lift, 33" Nitto Trail Grapplers, Warrior Front Bumper, Rear Bumper, Side Steps, Bed Rack, Roof Rack, Side Plates, Entry Guards, Spare Tire Carrier, Lower Tailgate Cover, Wurton LED's
    ** Warrior Products Group Buy **
    Group Buy Ends: 10/27/17
    Discount Structure:
    1 - 10 Products = 10% Off
    11 - 20 Products = 15% Off
    21+ Products = 20% Off
    Please note that we are counting the number of products sold, not entrants. If one person orders multiple products, they will be counted as multiple products towards the total count. (i.e. Person A orders (4) #4381. Total Order Count = 4)
    Pricing (Regular | 10% Off | 15% Off | 20% Off):
    #4370 - $125.54 | $112.99 | $106.71 | $100.43
    #4375 - $121.40 | $109.26 | $103.19 | $97.12
    #4381 - $135.79 | $122.21 | $115.42 | $108.63
    Shipping:
    $8.00 Flat Rate Shipping will be applied to each order to the lower 48 states. Alaska/Hawaii will be charged at the regular rate. Canada will be charged at the regular rate.
    How to Purchase/Sign-Up:
    Post in this thread or send us a PM saying that you would like to be included. We will contact each participant via PM and request contact information. This contact information will only be used to acquire payment information and shipping addresses.
    Entrants | Products:
    1. tarandus | 4375
    2. Shellshock | 4375
    3. Shellshock | 4375
    4. Alloutdrs1 | 4381
    5. blu92in99 | 4370
    6. blu92in99 | 4375
    7. lilyota12 | 4375
    8. ChucktownTaco | 4375
    9. johnny6 | 4381
    10. Boz1285 | 4375
    11. Boz1285 | 4375
    12. CoolRadBroTaco | 4375
    13. CoolRadBroTaco | 4375
    14. Mad Machinist | 4375
    15. mkempf87 | 4375
    16. mkempf87 | 4381
    17. 000doodie000 | 4370
    18. 21wrx21 | 4370
    19. koloheboy | 4370
    20. DrFunker | 4370
    21. BlueHeli | 4375
    22. Honeybadger415 | 4370
    23. Honeybadger415 | 4381
    The following products are eligible for this group buy:
    MOD Box (#4381)
    • 100% Designed, Manufactured, and Welded in the USA.
    • Designed to provide an additional storage solution for the factory bed channels of the 2005 - 2017 Toyota Tacoma.
    • The MOD Box allows for gear to be stored securely inside the box or hung outside the box using the full, standard MOLLE patterning.
    • Lockable using any padlock or cable lock to keep your gear from being stolen.
    • No rattle guarantee from the heavy-duty draw-tight latch.
    • Make use of the wasted space above the Toyota Tacoma wheel wells by adding an 18" MOD Box for tools, camping gear, recovery gear, etc.
    • All Hardware Included. No drilling or cutting required.
    For More Product Photos: Click Here
    QuickLatch Shovel/Axe Mount (#4375)
    • Designed to provide a solution to mount a shovel, an axe, or any other similarly sized tool to the factory bed channels of the 2005 - 2017 Toyota Tacoma.
    • Easily adjustable to grip all handles measuring between 7/8" diameter to 1-1/2" diameter.
    • Fully lockable using any padlock or cable lock to keep your gear from being stolen.
    • Complete and quick access to your tools with the simple-to-use clamping mechanism.
    QuickLatch Off-Road Jack Mount (#4370)
    • Designed to provide a solution to mount an Off-Road Jack to the factory bed channels of the 2005 - 2017 Toyota Tacoma.
    • Complete and quick access to your Off-Road Jack with the simple-to-use clamping mechanism.
  2. Oct 5, 2017 at 6:00 PM
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    This is great! Thanks so much for doing this. A double clamp that would hold both a shovel and axe would be very useful. I'm in.
  3. Oct 5, 2017 at 6:14 PM
    Shellshock
    Iowa
    In for 2 sets of 4375
    WarriorProducts[OP] likes this.
  4. Oct 5, 2017 at 7:28 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    I'm in for a mod box #4381, will you be adding any other products to this? I would be interested in a set of your side steps.
  5. Oct 5, 2017 at 7:53 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    1x #4370
    1x #4375
    Gracias!
  6. Oct 5, 2017 at 9:33 PM
    marinetaco
    marinetaco Well-Known Member
    Bobby
    2005 Tacoma TRD
    Hey guys. If anyone is interested on feedback about these, listen up. These things are freaking awesome. Warrior Products needed some trail testing done and I have to say. I have been through some crazy trails and not once did my ax fall off. The latches are adjustable depending on the size of your ax, shovel, or whatever you want secured. Good luck WP! Great product guys.
    Bobby - Team Overland
  7. Oct 6, 2017 at 7:18 AM
    WarriorProducts
    WarriorProducts
    It will hold pretty much anything between 7/8" diameter and 1-1/2" diameter. We figured people would also be using it for kayak oars, canoe paddles, etc.
  8. Oct 6, 2017 at 7:27 AM
    WarriorProducts
    WarriorProducts
    This is sort of a test-run group buy for us. If this works out well, we will likely continue offering them. The trouble with some of our other Tacoma products is that they are required to go truck freight due to size. This pushes the shipping cost up and makes the discount look less appealing. We will work out the details though and make sure the TacomaWorld users have access to the products that they want.
    ChucktownTaco likes this.
  9. Oct 6, 2017 at 7:29 AM
    lilyota12
    lilyota12 Well-Known Member
    Shredona
    2012 Tacoma DCSB 4.0 TRD Off-Road
    See Build Thread
    In for 1 x QuickLatch Shovel/Axe Mount (#4375)
  10. Oct 6, 2017 at 10:49 AM
    ChucktownTaco
    ChucktownTaco Member
    Marcus
    2017 Crew Cab Toyota Tacoma TRD Sport LB
    Put me down for 1 x QuickLatch Shovel/Axe Mount (#4375)
  11. Oct 6, 2017 at 12:37 PM
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    Is there one clamp that holds both shovel and axe? I only saw the clamp that is either shovel or axe, not both. (if there was a clamp that held both at the same time, I would definitely be in, these are pretty cool)
  12. Oct 6, 2017 at 12:43 PM
    WarriorProducts
    WarriorProducts
    At this time we only have mounts for one, not a double.
  13. Oct 6, 2017 at 12:45 PM
    johnny6
    johnny6 Unknown Member
    Northern California
    '17 DCLB 4X4
    Yeeeeeee
    I'll take a Mod box #4381
  14. Oct 6, 2017 at 12:46 PM
    000doodie000
    J
    On your site you also list a quick latch offload jack mount but it links back to the axe/shovel mount. Is there a similar mount for a hilift?
  15. Oct 6, 2017 at 12:49 PM
    WarriorProducts
    WarriorProducts
    Woops! Nice catch. We fixed it on the website. The title was wrong on that product page, but all the information and images are correct for the #4370 QuickLatch Off-Road Jack Mount.
  16. Oct 9, 2017 at 6:18 AM
    Boz1285
    Boz1285 Well-Known Member
    Bryan
    2016 Barcelona Red Tacoma Off Road
    BAMF grille, ARE Overland, PrinSu Rack
    In for two of the 4375 axe/shovel mount
  17. Oct 9, 2017 at 10:33 PM
    CoolRadBroTaco
    CoolRadBroTaco Well-Known Member
    Charlie
    Durango
    2017 DCLB TRD Off Road 4x4 White
    I'd be in for two sets of the 4375 axe and shovel mounts
  18. Oct 12, 2017 at 8:24 PM
    BlueHeli
    BlueHeli Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
    This is a great idea. I like the clamp for shovels and axes. I might be in for a single, I got to think about that. I will be here if you ever create a double axe/shovel combo. Can't really think of a use for the basket.
  19. Oct 12, 2017 at 9:44 PM
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Any pictures with a high lift mounted? I'd like to see how it sits.
    PNWTacoma and ChucktownTaco like this.
  20. Oct 13, 2017 at 3:25 AM
    macdadmorgan
    macdadmorgan Clean like ammonia, Sick like pneumonia
    IG@overlandonthefly
    W-Mass
    17 TRDORMT
    Things to get me in over my head
    Any chance that you could discount pn 10370 and 10375 ? They are the quick latches, with out the T-track hardware.
    Thanks
    Morgan
