Groupleader
Discussion in 'Technical Chat' started by Groupleader, Dec 29, 2009.
  1. Dec 29, 2009 at 7:34 AM
    Groupleader
    Groupleader [OP] Member
    Dave
    North Phoenix,Arizona
    Have a question I need cleared up, 2009 taco offroad package double cab with factory diff lock. Question is , will the diff lock work in two wheel drive, or does it have to be in 4 hi or 4 lo,I was told that it only worked in 4x4 mode. If anyone knows for sure id appreciate knowing what modes it works in. Thanx...
  2. Dec 29, 2009 at 7:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only works in 4low. There is a mod you can do to make it work in all ranges
  3. Dec 29, 2009 at 7:36 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    I'm pretty sure it only works in 4lo
  4. Dec 29, 2009 at 12:16 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Thats bad ass! :cool:
  5. Dec 29, 2009 at 3:03 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Wouldn't it work in 2wd as well?
  6. Dec 29, 2009 at 3:13 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    He has a 2009. isnt the grey wire for the first gens? i know when i did mine to my 2nd gen i had to run all those wires in the ECU behind the glove box through a relay.
    Also yeah once you do the mod it works in 4 hi and 2wd. its pretty easy if you follow the steps. i was nervous but it worked out just fine. i'll look for the link
    Edit: here it is Locker Anytime scroll down till you see it say "locker anytime"
