Grout & Slate cleaning & sealing?
Discussion in 'Off-Topic Discussion' started by Janster, Apr 6, 2010.
  1. Apr 6, 2010 at 6:38 AM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Hey Gang,
    We have a foyer that's covered with slate/grout. I absolutely love this part of the house, but its in desperate need of a cleaning. I would assume it needs to be sealed also? It's original to the house - probably since 1975ish.
    The grout is definately pourous....looks gray (like cement).
    I'm not too worried about the slate (per say), because it looks fine. The grout looks very dirty in some areas. The pictures don't do it any justice for the way it looks. The only thing I've done over the years, is a damp mop/vacuum.
    I don't even know what type of grout this is and wouldn't even know where to begin to search.... I've read about using 50/50 mixture of peroxide & water.
    I've also read using shaving creme? :confused:
    Any thoughts are greatly appreciatted!!
    Thanks!!
  2. Apr 6, 2010 at 6:44 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    it very well might be cement not grout. it would cost alot to fill in those overly large joints with grout. as far as cleaning the grout it has been soaked in and you prolly wont have much luck. i dont have much as far as advice on cleaning the slate other than water and elbow grease.. we always used water/sponge or chemical that you cant buy W/O a lisence
  3. Apr 6, 2010 at 6:58 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    I somehow found that if you spray that oven cleaner stuff on the grout and scrub it with a good brush, it looks brand new. However, i probably took off every bit of sealant and its gonna look like shit really fast. Live and learn I guess.
  4. Apr 6, 2010 at 7:05 AM
    Janster
    Jandy
    Lancaster, PA
    I thought you were gonna say...."It took off every bit of skin from my hands"
    That stuff is nasty and will eat holes in your skin. Ask me how I know. :rolleyes:
  5. Apr 6, 2010 at 7:12 AM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    Muriatic acid. You can buy it at most home improvement stores (its obviously diluted). It is the only thing i know of that tackles grout. It will actually take the top layer off, making it look new. It does smell pretty strong, so do it on a nice day where you can open windows if possible. You still might have to scrub a little. Green scotch brite scrubbies work great. Wear rubber gloves. Just follow directions on the bottle. And don't get it on anything else like finished wood. After applying and cleaning that off, just throw some sealer on there. The sealer is also at lowes/ home depot and will be in the tile section. There is one specifically for slate. Wipes on with a sponge, let it sit for a few hours without people/ dogs walking on it. presto, floor looks new!
    Edit:I actually do this stuff for a living and wouldn't mind helping if you need it. I didn't realize you lived in lancaster. I'm right in Newark.
  6. Apr 6, 2010 at 7:17 AM
    thecoldone06
    thecoldone06 Well-Known Member
    If you have a steam cleaner, those work great on grout.
  7. Apr 6, 2010 at 7:19 AM
    ShaShasBoo
    ShaShasBoo Well-Known Member
    Casey
    Lexington, KY
    06 DC Prerunner
    Not sure on the grout, but I do know that they slate needs to be sealed. Our kitchen floor is slate tile. I seal it atleast once a year with multiple layers. The sealant wears off with normal foot traffic, and with our 75 dogs running across it. I don't recall the brand of sealant I use. Let me know if you want the name of it and I'll check it out when I get home tonight.
  8. Apr 6, 2010 at 8:49 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Try vinegar and a toothbrush first. If that doesn't work, move on to what others have suggested.
  9. Apr 6, 2010 at 7:51 PM
    Janster
    Jandy
    Lancaster, PA
    Thanks Gang!! I'll try the vinager and the Peroxide/water method first.
    The acid and oven cleaner sounds soooo.....violent! The way I am, I'd probably have that shit all over the walls (because I'm a clutz - laugh).
    I'll let ya know if I have any luck.
  10. Apr 7, 2010 at 10:54 PM
    Janster
    Jandy
    Lancaster, PA
    Tried the vinager/toothbrush.....didn't do anything.
    Tried the peroxide/water/toothbrush....didn't do anything.
    Tried straight peroxide/toothbrush....didn't do much a all (foamed up).
    Tried Dawn detergent/water/toothbrush... this did the best so far.
    I'm gonna try Windex (or similar window cleaner) & bleach/water or just straight bleach.
    If all luck runs out, I'll work my way up to the more violent chemicals!
    Thanks guys/gals!
  11. Apr 7, 2010 at 11:02 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    muriatic acid is extreme for a lived in , finished house , if you use that , don't get it on the carpet or the woodwork or your skin or metal or anything BUT the grout lines , and you need to neutralize it with water , so it's not the best choice as I said ,
    OZ
  12. Apr 7, 2010 at 11:09 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Janster, You can try TSP. Its a hard surface cleaner that I use when I coat garage floors. It pulls anything out of concrete so I'm sure it would do the same with grout. You can get it at Ace Hardware in the cleaning supplies. It comes in a little white tub. You mix a little bit in water and then have at it. Its nothing crazy like acid but I'd wear rubber dish gloves because sometimes it can give you a lil bit of a rash.
  13. May 5, 2010 at 4:16 AM
    Janster
    Jandy
    Lancaster, PA
    A little procrastination :eek:..... still trying to find that miracle cleaner.
    Bought some stuff at the local Depot, and that didn't work worth a crap. :rolleyes:
    The guy at Depot said to try Tilex - which I already have at the house. Actually, it did really well on some of the areas but wasn't able to clean the worst areas. I'll stop by Home Depot again and see if they have anything else that you guys have already mentioned.
