Growling Noise Coming From Right Front
Discussion in '1st Gen. Tacomas (1995-2004)' started by tjohn03, Apr 23, 2009.
  1. Apr 23, 2009 at 1:20 PM
    tjohn03
    tjohn03 [OP] New Member
    Florida Pan Handle
    2003 Tacoma Double Cab 4x4
    I've developed a growling or what you might say is a low howl. I've had a couple of ppl mess with but nothing certain as of now. I'm shying away from the idea of a wheel bearing because its not a grinding noise. It increases a little with speed but pretty much maintains a steady loudness. If your driving and take a right turn it goes away until you get about a 1/4 turn away from straightening up then it will come back. Thats puts me guessing that it is gonna be in the right side since it quits when you turn and take the load off of that side. I don't have aggressive tires and it is alligned perfectly, it just freaking growls!! Any help would be a huge help. By the way its a 2003 Tacoma Double Cab 4x4
    Thanks,
    John T.
  2. Jul 6, 2010 at 2:25 PM
    ywen
    ywen Well-Known Member
  3. Jul 6, 2010 at 6:49 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    most toyotas dont grind when the wheel bearing is bad. most of them howl and i would say that its the right front because the noise goes away when you unload it and most times gets louder when you load it. put a right front wheel bearing in.
  4. Jul 6, 2010 at 10:25 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    x2
