growling sound in 08 V6
Discussion in 'Technical Chat' started by JohnnyRazorhead, Sep 15, 2011.
  1. Sep 15, 2011 at 4:56 PM
    JohnnyRazorhead
    JohnnyRazorhead [OP] Member
    Fort Scott, kansas
    08 tacoma trd double cab long bed 4X4
    I have an 08 double cab 4X4 and have a growl coming from the front end I believe. I rotated the tires changed oil and diff fluids, greased drive shaft. CV joint boots are in good shape. Put front end up and it seems tight, I couldnt get front tires to wiggle (checking bearings). I do think the carrier bearing on the drive shaft is worn. It is definately in the drive system and not the motor as it does it when ¥ou are coasting etc. any body else have this problem or know what it might be. Thanks in advance.
  2. Sep 15, 2011 at 4:58 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Wheel bearing? :notsure: does it make the noise all the time, only when turning, only when braking?
    how many miles do you have on it?
  3. Sep 15, 2011 at 5:00 PM
    JohnnyRazorhead
    Fort Scott, kansas
    its got 117,000 all highway. I use it for my work. no hauling, just driving
  4. Sep 16, 2011 at 4:41 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Does it go away when you put it in 4wd?
