Grumbling noise at low RPM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spruced UP, Aug 16, 2017.
  1. Aug 16, 2017 at 6:14 AM
    Spruced UP
    Spruced UP [OP] Well-Known Member
    Eric
    Jacksonville, FL
    2013 DCLB PreRunner TRD Sport, Spruce Mica
    I've recently noticed a light grumbling noise has developed from underneath the truck. I have about 117k miles on it. It almost sounds like an exhaust leak, but it's not always present. I usually only hear it 1)briefly at startup, and 2)at low RPM's mostly noticeable when I'm backing up. I inspected what I could underneath and around the exhaust pipe and other associated components, but didn't see any holes or apparent weak spots. It definitely sounds like an air noise, not something rattling loose, but of course I could be wrong about it.
    Any thoughts?
  2. Oct 17, 2017 at 12:29 PM
    Spruced UP
    Eric
    Jacksonville, FL
    Figured I would circle back to this for an update, in case anyone has this issue. I had my truck at the dealer for an overdue service. I asked them to check it out, but they didn't notice the noise. So, they asked me to come back and point it out to the tech. Once I drove with them, I could easily point it out. It turns out that the intake air box connection to the truck body/firewall had worked its way loose, and that's what was rattling. They pushed it back in, but I don't know how well they secured it, because I think I hear the noise starting again. At least now I know what it is, and can try to make a more permanent fix.
    ElBlancoTaco likes this.
  3. Oct 17, 2017 at 12:41 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Loosen the clamp on the air box and turn the hose clockwise to put tension on the other end and hold it in place when you tighten the clamp.
    Spruced UP[OP] likes this.
  4. Oct 17, 2017 at 12:44 PM
    Spruced UP
    Eric
    Jacksonville, FL
    Thanks, I'll give that a shot.
  5. Oct 17, 2017 at 12:46 PM
    roytown
    roytown Well-Known Member
    2015 4x4 DCSB TRD OR
    King 2.5s, Total Chaos UCA, OME springs, BAMF sliders, C4 rear bumper, Pelfreybilt IFS skids and front bumper, Baja pro and sport lights, teq custom headlights, Katzkin leather seats.
    Hmmmm I've had a very similar noise as well. I'll give it a shot!
  6. Aug 11, 2021 at 5:32 PM
    trinityalper
    trinityalper New Member
    Just in case anyone else is running into this issue, Larzzzz’s fix worked like a charm for me. As soon as I felt the intake air box, I could tell it was probably the source of the rattle/grumble. Larzzz’s fix puts just enough pressure on that connection to prevent any further rattling. Thanks a bunch man!!
    for reference I’m in an ‘06 access cab 4x4 with 118k miles.
    Larzzzz[QUOTED] and TnShooter like this.
  7. Mar 17, 2025 at 4:45 PM
    Comataco
    Comataco Well-Known Member
    Jerry
    Nine Mile Falls , WA.
    2013 double cab 4.0 bronze / brown
    nothing much yet , wheels , seat covers , larger tires , tool box
    Going to check this out on mine ,been chasing that noise & gets expensive going into shops & paying for tech's who can't here the noise (Hell my wife can hear it)!
  8. Mar 20, 2025 at 3:35 PM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    My '07 has had the "grrr" sound forever it seems and my air box intake wasn't loose, BUT it was still the source of the sound. Certain low RPM it was vibrating against the truck body/firewall. I put a couple washers under each connection on the air intake and Wa Lah, no more Grrrr sound.
  9. Mar 20, 2025 at 4:42 PM
    Comataco
    Jerry
    Mmmmmmmmm? something to check out but I think my air box is different ? Thanks PS: just noticed you have a o7 & a 2014 ..ok Just ran to the store & back a few miles & louder than ever idles faster in park @ 900 RPM by the time I got my tools to take the engine cover off it had got much quieter . Also curious about Belt & Idler & tensioner & Pulleys ? Every shop I go to says they can't hear anything but I don't think they really pay attention ,heck my wife can hear it . Tough to find a Tacoma shop around Spokane & I know there has to be one of those everyone goes to guy's.
