Guage Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Will Bell, Feb 12, 2012.
  1. Feb 12, 2012 at 4:58 PM
    Will Bell
    Will Bell [OP] Member
    As some of you may know I have a 2001 4cyl 5sp single cab Tacoma. I was wondering if anyone has put a tachometer in a truck like mine. I don't think I will rev it so high that it blows up but I would still like to know how high it is reving. I have seen the digital guages, but I don't know if any of those have a tach setting. Any help is greatly appreciated.
  2. Feb 13, 2012 at 8:12 PM
    Will Bell
    Anyone?????? I know ther has got to be someone on this huge forum that has aftermarket gauges in their 1st gen Tacoma.
  3. Feb 13, 2012 at 8:16 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    what year do you have?
  4. Feb 13, 2012 at 8:24 PM
    sir1123
    Charleston
    well if it is above 1996 you should get the scangauge II. it is a digital gauge and yes it has a tack gauge in it along with about twelve othere gauges that are used for monitoring you engine. water temp, air intake temp, mpg, tps, and more. worth the $100 somthing. or you can get the Ultra gauge which is a lttle better looging module and bit cheaper. both just plug into obd2 port. hope this helps.
