Guage pod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acgreen01, Dec 7, 2020.
  1. Dec 7, 2020 at 5:36 PM
    acgreen01
    acgreen01 [OP] Well-Known Member
    Andrew
    2012 silver 4wd regular cab
    I am installing a oil pressure guage. Does anyone make a pillar guage pod? If not where and what is the best place for mounting it?
  2. Dec 7, 2020 at 6:37 PM
    SimonTaco
    SimonTaco Well-Known Member
    Simon
    Tacoma 2012
    Stock
    i have one from wish, simply heated it up to shape the plastic and glued it down with loctite 5910 ill get a pic 2morrow
    acgreen01[OP] likes this.
  3. Dec 7, 2020 at 6:38 PM
    acgreen01
    Andrew
    Thanks
  4. Dec 8, 2020 at 4:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lotek makes a pillar gAUge pod. Craven Speed makes a steering column dual gauge pod.
