Guess tacos cant do everything
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tundrataco, Mar 22, 2014.
  1. Mar 22, 2014 at 2:04 PM
    tundrataco
    tundrataco [OP] Well-Known Member
    eastern townships, quebec
    front bilsteins 2.5" lift, rear aal 2.5" lift, flowmaster 40 series muffler, kenwood headunit, ultraguage, allpro bolton sliders
    had our 16' flatbed trailer out in a field, figured id try and get it out, it was warm today the snow was melting and packed.. i gave it 4 shots before the strap broke, i did budge it though! then i tried a heavy chain, as soon as it tightened the truck started to sink in place. so i said screw it and plugged in our IH tractor... had fun though!
    i would have got it if the strap didnt break..
  2. Mar 22, 2014 at 2:10 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Dang what's your AO? In SC PA its 60 degrees and sunny out.
  3. Mar 22, 2014 at 2:25 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    ATRAC woulda got it done.
  4. Mar 22, 2014 at 2:43 PM
    tundrataco
    im in quebec canada... still tons of snow out here, there calling for 55 degrees or so next week hopefully it will melt it down some..
  5. Mar 22, 2014 at 5:58 PM
    clc clc
    PA
    TO GOOD WEATHER :cheers:!!!
  6. Mar 22, 2014 at 6:53 PM
    TacoBrah
    Sean
    How does having 2 shackles help?
  7. Mar 22, 2014 at 6:56 PM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    I've got a similar story, I tried pulling a trailer up a big gravel hill just last week..Didn't make it:( Then I tried pulling my truck up with an excavator and broke the strap! You're right, I guess they can't do everything
  8. Mar 22, 2014 at 7:03 PM
    ailll1
    ailll1 Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
    What region? Looks like there's not much snow compared to where I live. Even if spring has come, I don't think any of it melted yet!
    Nice looking truck though!
  9. Mar 22, 2014 at 7:04 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    You guys are looking at this all wrong. Tacos CAN do everything. The STRAPS on the other hand can't... :)
  10. Mar 22, 2014 at 7:06 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Airing down may have helped, too. At least OP has Duratracs, which are good in the snow.
  11. Mar 22, 2014 at 7:07 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Because if you're a using an actual snatch/recovery strap, it will have loops on both ends. You're not supposed to loop the straps around, so shackles allow you to use the strap the way it was intended.
  12. Mar 22, 2014 at 7:21 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    One for each end of the strap to attach the loop in the strap to the recovery points. An appropriate sized/rated shackle won't become a projectile like those crappy hooks will when they open. In the OP's case, it was a very good thing the nylon strap itself broke before one of the hooks opened up.
  13. Mar 22, 2014 at 7:22 PM
    tundrataco
    eastern townships, im an hour east of montreal, you?
  14. Mar 22, 2014 at 7:23 PM
    TacoBrah
    Sean
    I see. Couldnt you use a tow ball or hook on the truck?
  15. Mar 22, 2014 at 7:24 PM
    tundrataco
    ya in hindsight it was a bad idea hahah, i did think just as it broke "what would happen if that hook came flying back....."
  16. Mar 22, 2014 at 7:25 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No
  17. Mar 22, 2014 at 7:26 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Yup, I wasn't commenting to give you a rough time, rather, to prevent rough times for anyone reading.
  18. Mar 22, 2014 at 7:28 PM
    TacoBrah
    Sean
    Why? Not strong enough?
  19. Mar 22, 2014 at 7:29 PM
    Dusty taco
    Dusty taco Well-Known Member
    Eli
    NorCal
    05 DC SB 4X4 SR5
    Magnaflow 2.5" Exhaust, Satoshi Style Grill, Led floods behind Grill, Firestone ride-rite airbags (rear), blue sea fuse block. Custom bed bar with shovel mount and utility led lights
    Tacos can't do everything? You obviously didn't get the trd flight package from the dealer haha.
  20. Mar 22, 2014 at 7:29 PM
    OZ-T
    Peter North
    British Columbia
    Correct
    Use the tow hitch
