Guess who drilled a hole in his fuel line?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fred54, Jul 5, 2019.
  1. Jul 5, 2019 at 10:27 AM
    fred54
    fred54 [OP] Member
    This guy! Drilled the drain holes in my bed a little bigger for the drain tubes for my backflip cover. Was super careful but I guess not careful enough. Noticed my check engine light on today and went to fill up the gas tank on my way to the auto parts store for a code reader when gas just started pouring all over the ground. Posting this as a testament to my own stupidity and a warning to others. Took about ten days to show up so I must have barely nicked it and then tank pressure probably blew it.
    Taking it for a week's vacation back home today but not anymore. Will sulk in my wifes car. I am an idiot.
    Any advice on how to fix it? I'm guessing I need to pull the plastic bed out and just replace the line from above.
  2. Jul 5, 2019 at 10:27 AM
    tcjacado
    tcjacado Well-Known Member
  3. Jul 5, 2019 at 10:29 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Welcome to TW, good luck. I bet this isn’t helping your fuel consumption
  4. Jul 5, 2019 at 10:34 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    um, no, you weren't.
    gsubioguy, Koolbreeze7, m3t5 and 13 others like this.
  5. Jul 5, 2019 at 10:38 AM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    the tacoma bed mounting bolts are in the bed, easy to get to.
    you will need to unplug wiring to the tail light and disconnect
    the tube from the gas tank to the bed. then im guessing you
    can tilt the bed and support it with a 2x4. thats what i did
    on my chevy pick up when i needed to replace the fuel pump.
  6. Jul 5, 2019 at 10:38 AM
    TacomaIvan19
    TacomaIvan19 Well-Known Member
    2019 TRD Sport
    Tailgate Inserts Black Weather Tech Mats Rekgen Mud Flaps
    Don't beat yourself up so much. Stuff Happens. You would only be an Idiot if you did it again and again.:pccoffee:
  7. Jul 5, 2019 at 10:55 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Stuff happens man. Now you have a learning opportunity on your hands.
    At least you didn't drain the trans fluid pan while changing oil and then argue that you didn't.
  8. Jul 5, 2019 at 10:57 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You need to discharge the fuel system pressure and disconnect the negative battery terminal before you do anything.
  9. Jul 5, 2019 at 11:04 AM
    Gunshot-6A
    Conner
    Everett, WA
    Having a fire extinguisher around would be a good idea too.
  10. Jul 5, 2019 at 11:07 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Crawl around under your truck and see if the fuel line is accessible. Perhaps it is easier than you think. Put your eyeballs on it.
    And, welcome to Tacoma World!
  11. Jul 5, 2019 at 11:10 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Not like that ever happens here...... :D:D:D:D
  12. Jul 5, 2019 at 11:12 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    You’re not the first. I have seen a few of these threads. At least one time the pro installer did this.
    Malvolio, shakerhood and tcjacado like this.
  13. Jul 5, 2019 at 11:13 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    You're not done yet. Two more steps till you're a PRO:
    - drain the transmission fluid instead of the oil and add 6qt of oil to the oil.
    - open the drain plug on the differential fist only to discover the fill plug is stuck.
    (yes, people have done this)
  14. Jul 5, 2019 at 11:18 AM
    81shark
    81shark Well-Known Member
    this is my all time favo
    Malvolio and hiPSI like this.
  15. Jul 5, 2019 at 11:19 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    lol 3rd gen shenanigans.
  16. Jul 5, 2019 at 11:19 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    This is actually the second time I’ve heard of this on TW....the first was a professional shop did it to a member’s Tacoma. Maybe run the drill in reverse so the bit doesn’t pull thru the material its hard to stop the torque of a drill even going slow.
    Malvolio and wilcam47 like this.
  17. Jul 5, 2019 at 11:21 AM
    Old Swamper
    Old Swamper Tacoma World Poor
    Will
    Northern WI.
    2012 Black Tacoma TRD OR
    5100 & OME 884 AAL
    Don’t feel bad. On My new Ranger Bass Boat while mounting the motor on the back the “pro”drilled two holes in the fuel cell and didn’t even know it till he went to fill up the tank for me.
    Gas was pouring out all over the lot. So it even happens to the best of them.
  18. Jul 5, 2019 at 11:23 AM
    Gunshot-6A
    Conner
    Everett, WA
    Oh trust me, there were some mighty 2nd gen shenanigans in the new days of the 2nd gen.
    Malvolio, fiftyxp, Boghog1 and 2 others like this.
  19. Jul 5, 2019 at 11:23 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    :rofl:
    tcjacado and Hobbs like this.
  20. Jul 5, 2019 at 11:24 AM
    TireFire
    Olympic Peninsula
    The fake scoop air intake was my favorite!!
    Junkhead likes this.
