Gumout liquid tune up, and other confusing products
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996_2.4, May 5, 2021.
  1. May 5, 2021 at 12:07 PM
    1996_2.4
    1996_2.4 [OP] Well-Known Member
    I have a 1996 with the 2.4. Starting to idle rough despite new plugs and dist cap & wires. Dirty injectors I'm sure. Heard the white can of Gumout liquid tune up is good, but the autostore has 5 different kind of Gumout injector cleaners and other brands. What is a good injector cleaner?
  2. May 5, 2021 at 12:13 PM
    Lgeekdws
    Lgeekdws Well-Known Member
    2015 Magnetic Grey V6 4x4 SR5
    Seafoam in a full tank.
  3. May 5, 2021 at 12:15 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
  4. May 5, 2021 at 12:21 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Small atomizer spray bottle filled with water , this will remove built up carbon in the intake , cyl head and piston
    With intake tube off exposing the TB and engine idling at 1500rpm spray water into the TB
    Speedytech7 likes this.
  5. May 5, 2021 at 12:25 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Don’t over think it. Buy a major brand on sale. Pay attention to ounces of product to a full tank (# of gals) of gas.
    se7enine likes this.
  6. May 5, 2021 at 12:31 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  7. May 5, 2021 at 12:37 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  8. May 5, 2021 at 12:46 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    B-12 Chemtool is a good cleaner. That's what I use when I can but if not then just some Chevron Techron cleaner will do. It's best to start using the stuff early on and not wait until carbon buildup gets bad enough to cause issues.
    TacoTaco02 likes this.
  9. May 5, 2021 at 12:47 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    If it's already hesitating, I'm not sure those snake oil bottles are going to work miracles on your engine.
    I mean, give it a shot, but I wouldn't be surprised if you end up having to take the injectors out and actually clean them.
    Wulf and Speedytech7 like this.
  10. May 5, 2021 at 12:49 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Which isn't all that hard on a 4cyl. Plenty of YouTube videos for a good DIY clean.
  11. May 5, 2021 at 12:50 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  12. May 5, 2021 at 1:03 PM
    patos tacoma
    patos tacoma Well-Known Member
    Save your money on the bottles, look up a 3rd party garage/shop that does a fuel injector clean with BG products, takes about an hour, under pressure, no cleanup, about $125
    Well worth it
    noticeable difference on my 2010......200K
  13. May 5, 2021 at 1:23 PM
    jbrandt
    Justin
    OCD much?
    yikes
  14. May 6, 2021 at 8:13 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Speaking of OCD, the nerds on bobistheoilguy.com would suggest that anything with Polyetheramine or PEA is what you want. Redline, Gumout All-in-one and Techron are all good choices for their high PEA concentrations (I'm sure there are plenty of others). No guarantee that any of these will make a difference.
    If you regularly fill up with Top Tier gas, then those additives are already present, so pouring a bottle of something into your tank is unlikely to help. Also, FWIW, I have never encountered convincing evidence that running Seafoam through the intake objectively improves anything; just makes a smoke show.
  15. May 6, 2021 at 10:40 AM
    Wulf
    rock raisin
    Careful with any of these treatments on an older vehicle. I've had Seafoam free up a bunch of crud that had settled in the tank and send it through to the fuel filter.
    Turned a poor running truck into a non-running truck.
    eon_blue likes this.
  16. May 6, 2021 at 10:45 AM
    eon_blue
    Azusa, CA
    I use B-12 ever since Seafoam started going way up in price, at least around here. From what I can tell it's the same stuff, for 1/2 the cost. I usually put a can in the tank if I'm doing a long road trip in the truck, which is maybe a couple times a year.
    TacoTaco02 and se7enine[QUOTED] like this.
  17. May 6, 2021 at 10:50 AM
    eon_blue
    Azusa, CA
    Use to run Seafoam through the TB, but the more I read about it the more it sounds like I'm probably doing more harm to the sensors and wreaking potential havoc than doing any good. Just put B12 in the gas tank now once or twice a year.
  18. May 7, 2021 at 8:51 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I mean to be honest low mileage vehicles shouldn't have issue to begin with, so they are not needed as much. BUT, running a can through every now and then can help from carbon build-up down the road. It will not prevent it but minimize versus no treatment.
    changing the fuel filter regularly as well will help keep the sediment that's in all fuel from reaching the injectors.
    also sustained running is far better than short trips, the longer you can keep the engine pumping at operating ranges the better burn-off and less build-up
    I run a can through when I remember to but definitely not every fillup or oil change
  19. May 7, 2021 at 9:39 AM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    I use B12 Chemtool sporadically in all my vehicles. Works great and cheap. Every so often I'll run Seafoam through the brake booster vacuum line.
