Gun Cleaning Thread - What do you use?
Discussion in 'Guns & Hunting' started by Janster, Apr 7, 2011.
  1. Apr 7, 2011 at 12:00 PM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Just thought I'd post up and find out what everyone is using in terms of gun cleaning solutions, etc.
    My husband and I clean our guns everytime we get out shooting - which might be twice a month. We have a bombardment of cleaning supplies and solutions.
    For the most part - the difficulties come when dealing with the barrels. My bodyguard is easy to clean since it only gets 50 rounds (factory ammo) thru it. Everything else - might see 100-200 rounds each (reloads). My husband uses plated bullets, so I can't imagine there's any lead buildup.
    I'll spend 30 minutes cleaning one gun (like the M&P 9C) and 20 of those minutes are working on the barrel and its still has slight carbon left.
    Here's a few of the solvents we use already:
    Hoppes #9, Hoppes Semi Auto, Break Free CLP, KG1 Carbon Remover, M-Pro 7
    Is there something you can literally SOAK the barrels in over a period of time that'll discolve or atleast loosen the carbon buildup?
  2. Apr 7, 2011 at 12:04 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    I like Gunslick bore scrubber. I also use the gunslick action cleaner which has a lube built in, works great for triggers systems.
    I have used sweets when shooting lots of surplous 5.56 ammo because it works so good on copper fouling.
  3. Apr 7, 2011 at 12:06 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I pretty much use Hoppes #9 exclusively
  4. Apr 7, 2011 at 12:09 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Everything Hoppes. No issues yet.
  5. Apr 7, 2011 at 12:14 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    I use Breakfree CLP. I heard that it was formulated for the military, but I don't know if that is true or not. I have been using it on all of my guns for the past 11 years without any problem.
  6. Apr 7, 2011 at 12:15 PM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
  7. Apr 7, 2011 at 12:15 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    CLP and Hoppes.
  8. Apr 7, 2011 at 12:16 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    x2. i use the same stuff
  9. Apr 7, 2011 at 12:17 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    i just the Remington Oil Wipes, you can buy it at WalMart. you can use it for the interior and exterior
  10. Apr 7, 2011 at 12:18 PM
    HMFD110
    HMFD110 Well-Known Member
    New York
    2011 Reg Cab 4X2
  11. Apr 7, 2011 at 12:52 PM
    GP100
    GP100 Well-Known Member
    Paul
    RI
    '06 TRD Offroad
    Just put your used patches under the seat...
  12. Apr 7, 2011 at 12:53 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    for my shotgun just 2-in-1 oil. does the trick fine. for nice riffles, hoppes.
  13. Apr 7, 2011 at 12:59 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    KG. They coat my guns, and I use their cleaners.
    I also grew up with the owners kids, so I gotta represent :D
  14. Apr 7, 2011 at 1:59 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    i spray some CLP down the barrel then i use Dupont Dry Film Spray with Teflon for lube...
    also use it on my motorcycle chains....
  15. Apr 7, 2011 at 2:07 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Hoppes #9, Break Free CLP
    I will leave the break free in the barrel overnight. Works well for me. Mostly reloads from gun shows. My own re loads are with Tite Group which seems to burn very clean.
  16. Apr 7, 2011 at 2:15 PM
    TacoAL
    TacoAL Well-Known Member
    AL
    The Gunshine State
    TC
    None (for now)
    Hoppe's and a .45 bore snake fallowed by a nice oil rubdown.
  17. Apr 7, 2011 at 2:15 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    hoppes and boresnakes here too
  18. Apr 7, 2011 at 4:22 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    It depends on the type of dirt/fouling.
    If it's just carbon dirt and lead down the pipe then good-ol' Hoppes #9.
    Hoppes #9 will not clean copper fouling from jacketed bullets. You need a copper cleaner. My favorite is Sweets 7.62 but it's strong stuff so it gets used occasionally. Use a nylon brush because it will start to eat a brass (has copper in it) brush.
    For all three (carbon, lead, copper) at once and if not very dirty I use Butch's Bore Shine.
    If you are cleaning a rifle or carbine PLEASE USE A BORE GUIDE before shoving a cleaning rod down it. Buck up and spend $7 on one. You will ruin the barrel throat and your accuracy goes down the tube.
    I do a few patches of solvent then the brush and then use my secret cleaning solvent. It's birchwood-casey's gun scrubber. This is like brake cleaner for guns. Blast a little down barrel and watch the crud pour out. You just need a few more dry patches to clean the rest out.
    Use a synthetic gun old on a patch. Rem oil is excellent.
    I love CLR for my AR15. It and compressed are does a great job on the lower section.
    I keep a bore snake with each rifle I own for field cleaning. I feel they don't scrub away the fouling as well as a barrel brush but they do an excellent cleaning up the solvent. It's like running 200 patches through the barrel.
    Good read for cleaners: http://www.frfrogspad.com/cleaners.htm
    Hope this helps.
  19. Apr 7, 2011 at 4:34 PM
    slimsdepot
    slimsdepot slimsdepot.com
    SoCal
    08 PreRunner
    I like Hoppes but might try that Break Free stuff mentioned above. I need to make a trip to turners to buy some stuff anyway. :)
  20. Apr 7, 2011 at 4:35 PM
    MMJ
    MMJ Well-Known Member
    Jack
    Denver
    2010 TACOMA TRD OFF ROAD
    Smitty Built nerf bars
    I use hoppes but will start using a product called ballistol with it too. I was watching a video on youtube and this guy said after he cleaned his bore and thought it was clean, it really wasn't because he ran some more patches with this ballistol stuff and his patches were black again.
