Gun Holster Mount
Discussion in 'Guns & Hunting' started by cdals, Jul 2, 2022.
  1. Jul 2, 2022 at 1:03 PM
    cdals
    cdals [OP] Well-Known Member
    Conor
    Mystic, CT
    6 Speed Off-Road
    GFC V2
    Have a 3rd gen and looking for an option to mount my holster while driving for more comfort and easier access. To be clear when I leave the vehicle the gun will be holstered on me and if it is left in the truck for any reason it will be locked in a liberty handgun vault. I'm right-handed and drive a manual so something on the side of the center console could work as long as it sits low enough so it doesn't interfere with shifting.
    Anyone mount up some molle panels either on the front of the seat so it sits between your legs or on the side of the center console? Does it require drilling? Other solutions?
    Thanks.
  2. Jul 2, 2022 at 5:49 PM
    p1smo
    p1smo Well-Known Member
    2003 Tacoma TRD 4x4 3.4L 5MT
    Relentless Stealth front + Relentless standard rear plate bumpers w/ D2 cutouts, 2x Rigid D2 floods front + 2x Rigid flush D2 floods rear, BAMF behind-the-grille light bar mount w/ 2x Rigid 6" bar floods, KING coilovers/springs + rear adjuster shocks, Deaver leaf springs, Total Chaos UCAs, BAMF rock sliders, BAMF LCA skids, Relentless front skid, Low-Range Off-Road gas tank skid, Marlin differential plate cover, Marlin E-Locker motor guard, Hawke HD brake pads, Trail Gear steel brake line kit, Marlin HD full clutch assembly, deckplate intake mod + AFE high flow filter, ARB CKMA12, exhaust dumped over rear axle, 32/11.5r15 Cooper Discoverer AT3 XLT, American Racing Baja 15x8, Viper alarm + fuel cutoff switch, and more Toyota OEM parts + replacements than I care to list
    NeoMag makes an attachment system that fits most standard holster clips so you can swap your holster from different mounts in your car or at your desk straight to your belt. You'd have to drill somewhere in your car most likely, but it's such a small mount it would be almost imperceptible.
  3. Jul 2, 2022 at 6:06 PM
    cdals
    Conor
    Mystic, CT
    6 Speed Off-Road
    GFC V2
    Thanks, I’ll definitely check that out
    Speedbird likes this.
  4. Jul 4, 2022 at 9:43 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Wet Okole has the option to have a holster sewn into the front of the seat cover when ordering. I have it and like it.
  5. Oct 25, 2022 at 4:38 PM
    AncaGrind80
    AncaGrind80 Well-Known Member
    Robert
    2022 MGM TRD Off Road
    I realize this thread is a bit old, but here's my setup. Molle panel from Victory 4x4. IWB holster clips on securely and is out of the way. Very happy with this. PXL_20221025_233401325.jpg
    bkhlrTaco's, kevinRR and auk like this.
  6. Nov 1, 2022 at 6:06 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Check out Holster Gator, they make a 3D printed mount that you can attached anywhere and slide any holster onto.
  7. Nov 2, 2022 at 5:22 PM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Suggest check your states CCW rules before proceeding. It's been a hot minute and then some since I took [Virginia] CCW class. But I think MAYBE, I recall something about this like;
    o Concealed on your person is cool
    o Open carry = OK (Also sitting in plain view on passenger seat)
    o inaccessible = Ok of course, to include locked in glovebox or case. Consol was a grey area... if lockable and key would have to be taken out of the ignition IOT unlock the consol was thought to be ok (Same as glove-box).
    X Concealed and accessible, but not on your person was a no-go (i.e. tucked between seat and centre consol (I assume magnet mount under dash would be the same)
  8. Nov 19, 2022 at 7:47 AM
    crazeflier007
    crazeflier007 Well-Known Member
    2019 Cement Tacoma TRD-Off Road 4x4
    Old Man Emu lift, TRD PRO rims with BFG All-Terrains, ARB Front Bumper with Warn Winch, Baja Designs LP6 lights and S2 Pro spots, TRD Intake, Prinsu Roof Rack, ARE Topper with Yakima Crossbars, lots more to come.
  9. Mar 9, 2023 at 10:13 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    We the People IWB and their mount.
    PiryongS and azshooter40 like this.
  10. Mar 10, 2023 at 4:31 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Did you screw it on or use the Velcro option? I’ve been looking at getting one.
  11. Mar 10, 2023 at 4:40 PM
    BigFatDynamo
    BigFatDynamo Well-Known Member
    Charlotte, NC
    2019 TRD OR
    Sticky holster inside a sticky holster. The larger has two screws with 3/4" plastic washers, mounted to the console. Much like everyone else, just a different holster.
    easy to remove while keeping holstered. Also a manual and I have no issues shifting.
  12. Mar 11, 2023 at 3:25 PM
    ThaiChillyTaco
    David
    I used both the velcro loop tape and screwed it into the center console. Double secure.
    It will take a week or two to get use it against your leg. Now it doesn't bother me at all. :oldglory:
    azshooter40 likes this.
  13. Mar 11, 2023 at 7:56 PM
    plurpimpin
    PDX
    Oof deal breaker for me. I hate shit against my leg while driving.
  14. Mar 29, 2023 at 10:08 AM
    sammyt38
    sammyt38 Well-Known Member
    Sam
    Gulf Coast
    2020 TRD OR MBM
    Title Mod, Eibach Stage 2, Headstrong AAL, Bakflip G2
    I toyed with several these ideas for months and could not make my mind up. Like a peasant I opted to just put my glock inside a soft holster and stick in the drivers side door bin... wow it sucks being poor
    Makes me think of a Facebook tag group called "YOUR VEHICLE IS NOT A HOLSTER" :rofl:
  15. Mar 30, 2023 at 11:02 AM
    PiryongS
    PiryongS Well-Known Member
    Practice drawing from that side of the console and then try the other side. You may find that it is easier to draw the sidearm from the passenger side
    ktbell444 likes this.
