Gun light
Discussion in 'Guns & Hunting' started by swtaco10, May 29, 2022.
  1. May 29, 2022 at 7:50 AM
    swtaco10
    swtaco10 [OP] Well-Known Member
    Dave
    South of Tampa
    2010 Tacoma TRD off-Road
    Bilstein 5100's, LED interior and puddle lights, 17" XD revolver's, Grabber A/T2's
    Looking for suggestions for a flashlight mounted on a 10.5" SBR. I'd like it to have 600 or more lumens, a pressure/tape switch with momentary/strobe/low function, rechargeable, decent battery life (60 mins). I've looked into the Streamlight ProTac 2 and Fenix TK11. I'd prefer to use the Arisaka mount if possible. I'd love $urefire but am on a budget. Anyone have any input? I'd also like to see what you guys are running and cable management too so post up some pics.
  2. May 29, 2022 at 9:02 AM
    swtaco10
    Dave
    South of Tampa
    Heard of OLight but haven't looked into them just yet. Sub $200 is in my price range for sure. I'll take a look.
  3. May 29, 2022 at 9:07 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Streamlight protac is decent, but Id highly recommend Modlite, Cloud Defensive or Surefire. Yes its more, but why cheap out on serious equipment?
    Strobe is a gimmick, a high/low setting is just more button pushes when you are falling to base level of proficiency. Stick with on/off.
    Modbuttons or the surefire tape switches work incredibly well and the SF tapes have a well proven legacy all through GWOT. I personally run the later. Others I know do push button tailcaps on white light for white light discipline reasons.
    ohcaltexscar likes this.
  4. May 29, 2022 at 9:16 AM
    Gunshot-6A
    Conner
    Everett, WA
    Just gonna put this out there, Olight has numerous documented QC failures and actually managed to directly kill a person in a battery failure before.
    What you do with that info is up to you.
  5. May 29, 2022 at 2:25 PM
    swtaco10
    Dave
    South of Tampa
    I'll check into Modlite as well. Seeing as lighting is a new topic for me, I'm open to all options at this point.
  6. May 29, 2022 at 2:35 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I've had a stream light Strion on my 12ga for a couple years still going strong, it doesn't have a tape switch (possibly aftermarket never looked into it) but should meet all other requirements.
    The Strion is an extremely durable light I've put a few through absolute hell and they all still work.
    Only complaint is if you use them frequently during a daily basis the tail cap switch can get fussy but it's easy to replace.
  7. May 29, 2022 at 2:35 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Had to look that up. Puts flashlight in mouth and leans into engine bay by car battery. Did he short it from the battery pos post to the body while it was in his mouth?
    I have an Odin on my 10.5, tape switch on side activated by thumb or palm.
  8. May 29, 2022 at 2:37 PM
    swtaco10
    Dave
    South of Tampa
    I use the Strion HL for work on a daily basis so I am more than familiar with it, hence my looking at streamlight. It does check all the boxes except I haven't found a decent mounting solution that doesn't seem cobbled together.
  9. May 30, 2022 at 6:50 PM
    p1smo
    p1smo Well-Known Member
    2003 Tacoma TRD 4x4 3.4L 5MT
    Relentless Stealth front + Relentless standard rear plate bumpers w/ D2 cutouts, 2x Rigid D2 floods front + 2x Rigid flush D2 floods rear, BAMF behind-the-grille light bar mount w/ 2x Rigid 6" bar floods, KING coilovers/springs + rear adjuster shocks, Deaver leaf springs, Total Chaos UCAs, BAMF rock sliders, BAMF LCA skids, Relentless front skid, Low-Range Off-Road gas tank skid, Marlin differential plate cover, Marlin E-Locker motor guard, Hawke HD brake pads, Trail Gear steel brake line kit, Marlin HD full clutch assembly, deckplate intake mod + AFE high flow filter, ARB CKMA12, exhaust dumped over rear axle, 32/11.5r15 Cooper Discoverer AT3 XLT, American Racing Baja 15x8, Viper alarm + fuel cutoff switch, and more Toyota OEM parts + replacements than I care to list
    I've been told the SF legacy switches can only handle like 80% output on ModLite, and to go with either Modbutton or Unity Tactical. Haven't had a good opportunity to test myself yet.
    Gunshot-6A[QUOTED] likes this.
  10. May 30, 2022 at 7:08 PM
    Gunshot-6A
    Conner
    Everett, WA
    Ive heard the same unless you use the DS00 tailcap.
    That said, they work quite well and are still bright as heck for cqb to intermediate ranges.
    p1smo[QUOTED] likes this.
  11. May 30, 2022 at 7:09 PM
    Key-Rei
    Key
    Florida
    I believe it.
    I had a 90° head Olight and the button silicone tore and the switch desoldered from the PCB within three weeks of light duty use.
    My c6hr or whatever Zebra light I replaced it with has been going strong for a few years now.
  12. May 30, 2022 at 7:10 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Link to a light killing a person, please?
  13. May 30, 2022 at 7:12 PM
    Gunshot-6A
    Conner
    Everett, WA
  14. May 30, 2022 at 7:13 PM
    Key-Rei
    Key
    Florida
  15. May 30, 2022 at 7:14 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    That makes more sense (not that that poor person died unexpectedly, that is utterly devastating).
    I thought someone was in a gunfight and blamed their battery for a death rather than the firearm holder.
    Thank you for the link. Appreciated.
  16. May 30, 2022 at 7:19 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    According to that thread, it sounds like the guy put the wrong battery in, the battery was at fault, not the light, and he put it in his mouth and then touched the battery terminal, not the wisest, etc. Not sure whether one instance means I shouldn't throw one on a pistol/rifle. First I've heard of it.
  17. May 30, 2022 at 7:25 PM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    Southwest Ohio
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    Dang, I guess I’m super cheap. I’ve got a 12$ Harbor Freight Quantum 580 lumen light stuck on mine. I mean, it works.
    Maybe… maybe I should look into something else.
  18. May 30, 2022 at 7:33 PM
    Key-Rei
    Key
    Florida
    First I ever heard of it too, and I just googled it and that's what I got.
    Dunno about the death but I can personally attest Olight's build quality and QC are lacking especially compared to Zebra light.
    Gunshot-6A and ohcaltexscar like this.
  19. May 30, 2022 at 7:38 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I have 3 zebralights currently. Wouldn’t mind upgrading a couple.
    Key-Rei[QUOTED] likes this.
  20. May 30, 2022 at 7:46 PM
    Key-Rei
    Key
    Florida
    Have you taken your gun out and shot it with the light? Especially quickly since mounting light?
    With my first gun light which was even marketed as a weapon light (albeit it was a cheap one) it would cut out and turn off from slug recoil due to the battery being pulled off the internal spring contact from the recoil forces.
    100% if your life depends on it you need to test your gear in the environment and conditions you are expecting it perform in, had I not known that light would cut off when firing and gotten into situation where I had to use the 12ga it would not be a good time if I lost my light after squeezing off the first round.
