GUNNY IS BACK
Discussion in 'Camelback Toyota Parts' started by gunny1005, Feb 20, 2017.
Thread Status:
Not open for further replies.
  1. Oct 13, 2017 at 3:32 PM
    #621
    gunny1005
    gunny1005 [OP] Well-Known Member
    Phoenix
    BEARING 90369-54002 $71.36
    SEAL 90312-95001 $15.84
    SEAL $90316-69001 $37.88
    RING 90521-99114 $5.60
    ROTOR 43515-35010 $20.84
    43524-35010 $17.02
    total for one side $168.54
  2. Oct 13, 2017 at 3:43 PM
    #622
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Thanks. I see you've included an ABS Tone Ring ( ROTOR 43515-35010 $20.84 ). Is this required for a non-abs truck?
  3. Oct 13, 2017 at 3:45 PM
    #623
    gunny1005
    Phoenix
    I just added it, incase you needed it
  4. Oct 13, 2017 at 3:58 PM
    #624
    Digiratus
    Roaming the PNW
    The RedHead
    Ah, ok. Thanks.
    TBH, I don't really know yet what all I need. I guess I will have to disassemble and see if I need more than just the bearings.
    Is everything symmetrical on this job? Are the parts on the driver and the passenger sides identical?
  5. Oct 13, 2017 at 3:59 PM
    #625
    gunny1005
    Phoenix
    Yes, parts are the same left and right side...
    Digiratus[QUOTED] likes this.
  6. Oct 13, 2017 at 5:17 PM
    #626
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    @gunny1005 receievd my stuff earlier this week btw. Thanks again for the quick service!
    gunny1005[OP] likes this.
  7. Oct 14, 2017 at 9:06 PM
    #627
    Hoangde
    Hoangde Well-Known Member
    @gunny1005
    Cost to my door :
    Sending Unit - Toyota (83320-04030) to San Diego, 92126.
    Kindly ensure that p/n is for 2009 Tacoma 4 cycl, AT
    Thanks
  8. Oct 15, 2017 at 7:49 PM
    #628
    jdubdvdt
    jdubdvdt Well-Known Member
    Tampa, FL
    01 4x4 Ext. Cab Impulse Red
    @gunny1005,
    how much for both (drivers and passenger side) LBJs and UBJs for a 99 V6 Prerunner, shipped to 33611? I also see people asking for flanged bolts for the LBJs, do they commonly break, or are they stretch to yield bolts? If either case I'll want enough to do my LBJs.
    Thanks!
  9. Oct 16, 2017 at 6:32 AM
    #629
    gunny1005
    Phoenix
    yes that is the correct part number, I would have to order it. Shows I can get next day... $68.22 shipped
  10. Oct 16, 2017 at 6:34 AM
    #630
    gunny1005
    Phoenix
    I do have them in stock
    43340-39585 $105.79
    43330-39815 $105.79
    bolts 90080-10066 $0.93 each
    Total shipped $219.02
  11. Oct 16, 2017 at 6:44 AM
    #631
    jdubdvdt
    Tampa, FL
  12. Oct 16, 2017 at 6:45 AM
    #632
    gunny1005
    Phoenix
  13. Oct 16, 2017 at 6:00 PM
    #633
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    @gunny1005 Could i please get a part number and a quote for these clips that hold on the rear seat panel in an 09 access cab? I need about 9 of these
    I believe the equivalent for 2016 access cabs is part# 90467-09240, not sure if theyve been superseded by this part#, but i know the ones in the newer trucks are red vs these being a teal/light green color
  14. Oct 16, 2017 at 6:40 PM
    #634
    Mike44
    Mike44 Well-Known Member
    Victoria, BC
    2015 Silver TRD Sport DCLB
    Canopy, Lund side steps, 42" light bar behind the grill, Custom mud flaps, Hood and Window visors, Firestone airbag rear suspension, Undercoated, Husky X act fit floor mats front and back, Door sill protectors...... More to come.
    I’m curious about the all weather flooring. 4 dr crew cab and shipped to Canada 509-623 Treanor Ave. Victoria BC. V9b0b1
  15. Oct 16, 2017 at 6:42 PM
    #635
    BassAckwards
    Also, i believe this is the part # youre looking for for a double cab auto trans
    58510-04870-B2
    Im sure gunny can confirm that for you though..
  16. Oct 17, 2017 at 7:10 AM
    #636
    gunny1005
    Phoenix
    Is the 90467-10161 the clip your looking for?
  17. Oct 17, 2017 at 7:21 AM
    #637
    BassAckwards
    Yes sir, that's the one
  18. Oct 17, 2017 at 7:46 AM
    #638
    gunny1005
    Phoenix
    I have 5 in stock, I can get the rest tomorrow $0.87 each
  19. Oct 17, 2017 at 7:49 AM
    #639
    BassAckwards
    Okay sounds good, go ahead and order 5 more so a total of ten in case I have any problems with losing one or breaking one. Please send me an invoice and I will get you paid sir. I appreciate all the help
    TacoTRD78 likes this.
  20. Oct 17, 2017 at 8:30 AM
    #640
    gunny1005
    Phoenix
    I will get them coming
Thread Status:
