Gunshot's Taco Build and Washington Debauchery Log...
Discussion in '2nd Gen. Builds (2005-2015)' started by Gunshot-6A, Oct 22, 2018.
  1. Aug 27, 2023 at 1:39 PM
    #2961
    Gunshot-6A
    Gunshot-6A [OP] Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Made a friend pulling the boat into Roche Harbor, WA today
    d.shaw, BOMBS, ginseng27 and 2 others like this.
  2. Aug 27, 2023 at 6:38 PM
    #2962
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    That’s a helluva boat.
  3. Aug 28, 2023 at 7:46 AM
    #2963
    ginseng27
    ginseng27 who knows?
    '17 DCSB OR
    not enough.
    is that your new toy you're goign to attach your bike to?
  4. Aug 30, 2023 at 8:36 PM
    #2964
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Once upon a time, I had a superior tell me to "get comfortable being uncomfortable." After I was promoted and reassigned to an area I didn't really want to be it.
    There is something to be said about being too comfortable in a job/position. You definitely grow and develope more when you are not.
  5. Aug 30, 2023 at 9:24 PM
    #2965
    ToyTech_PNW
    ToyTech_PNW OG Toyota Customer
    Jeremy Jamm
    NW-PNW
    2004 GX470
    AISIN Timing Belt Kit, cracked dash...
    Move over here to Kitsap County! No pesky ferry ride to visit the Olympics and housing is much cheaper. Plus side: if you work in SEA, you get to ride the ferry every day (my wife, a Seattle commuter, is punching my arm now )!
  6. Aug 31, 2023 at 3:15 PM
    #2966
    Gunshot-6A
    Conner
    Everett, WA
    Just spent a week in the San Juans on a boat. Friday Harbor seemed awfully inviting to me if I didn't have to be at work in person every day here in Everett. Maybe worth considering down the line if there's opportunity / remote work available.
    ginseng27, H3llRid3r and 08TRDOFFROAD like this.
  7. Sep 5, 2023 at 5:53 PM
    #2967
    Gunshot-6A
    Conner
    Everett, WA
    Finally have a probable cause of my mysterious starter issue. Bad starter solenoid. Talked to the local dealer service advisor and he confirmed that my suspicion was correct, and had the issue himself a few months ago.
    Gonna have to pay to get it serviced since the apapartment I'm in is a no vehicle maintenance clause type. Its a stiff bill vs do it yourself but whatever.
    08TRDOFFROAD, BOMBS, d.shaw and 2 others like this.
  8. Sep 5, 2023 at 8:52 PM
    #2968
    H3llRid3r
    SLcUT
    Could you do it in the parking lot of the parts store? I see it all the time. Not that you have to. Just saying it’s an option.
  9. Sep 6, 2023 at 1:27 AM
    #2969
    Gunshot-6A
    Conner
    Everett, WA
    I thought about it but if you look at rhe procedure to dismantle and reinstall a starter on a 2015, its a tight job. I probably could do it, but given the circumstances, Im just going to solve it the easy way.
    Esp because most of my tools are in a storage unit 5 miles away so if I need another extension, etc I cant just walk to the toolbox in my garage if I didnt grab something, etc.
    BOMBS and H3llRid3r[QUOTED] like this.
  10. Sep 6, 2023 at 7:30 AM
    #2970
    ginseng27
    '17 DCSB OR
    not enough.
    booooooo apartment.
  11. Sep 6, 2023 at 8:42 AM
    #2971
    Gunshot-6A
    Conner
    Everett, WA
    Yeah, I miss my dope garage in Utah...and my motorcycle. Have toyed with the idea of starting to look for a house around here, but prices are HORRID and the taxes are worse along with the commute. Def trying to keep my eyes forward, but the thought of backsliding and finding a new job next spring in UT is tempting to me every day.
  12. Sep 6, 2023 at 8:47 AM
    #2972
    ginseng27
    '17 DCSB OR
    not enough.
    you still have your place here don't you?
  13. Sep 6, 2023 at 10:08 AM
    #2973
    Gunshot-6A
    Conner
    Everett, WA
    Yep, which is why it'd be easy to just find job with a reasonable commute and come back. I do miss the state and the homies a lot.
  14. Sep 7, 2023 at 9:00 AM
    #2974
    Gunshot-6A
    Conner
    Everett, WA
    So...it's not the starter...most likely....probably...maybe
    Was fortunate that the " *click* and dead truck " sporadic issue happened as the runner was trying to pull my truck into the service bay so I got to show my service manager the issue in full. Ended up with him and 2 shop techs looking in the engine bay and the scanguage as I showed the issue and the fix, and after a bunch of on/off cycles, they ruled: yeah, that's not a starter issue or a alternator issue.
    Little bit of discussion later, we ended up back on my original theory of it being a battery or connection to the terminal issue.
    So downside is the mystery continues, the upside is that a new battery (even a Grp31 AGM battery) is cheaper than a starter replacement. I also already have new terminal posts in the truck so I can swap those as well to start knocking out probable causes.
    H3llRid3r, RyanL and ginseng27 like this.
  15. Sep 7, 2023 at 9:52 AM
    #2975
    Gunshot-6A
    Conner
    Everett, WA
    d.shaw and H3llRid3r like this.
  16. Sep 7, 2023 at 8:53 PM
    #2976
    H3llRid3r
    SLcUT
    Hasn’t this been going on for over a year now?
  17. Sep 8, 2023 at 7:08 AM
    #2977
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    starter replacement sucks. Have to partially remove the header
  18. Sep 8, 2023 at 7:53 AM
    #2978
    Gunshot-6A
    Conner
    Everett, WA
    Yeah, but has been progressively getting worse. Strangely/thankfully, it didn't rear it's head once while in the process of moving here.
    I def think it has to do with battery age and corrosion on the terminals. I think it has to do with the much damper air. I know it took a deep clean of my truck when I got here as well because it rehydrated all the gross that 9% humidity hides under the moon dust :rofl:
    H3llRid3r[QUOTED] and ginseng27 like this.
  19. Sep 9, 2023 at 10:56 AM
    #2979
    Gunshot-6A
    Conner
    Everett, WA
    Beach Zoomies (2023, colorized)
  20. Sep 9, 2023 at 7:34 PM
    #2980
    d.shaw
    d.shaw Well-Known Member
    2012 Silver TRD-OR
    Vagabond Drifter, King 2.5 coilovers, King 2.5 rear, Pelfreybilt front / rear bumpers and skids, rock sliders, Safari snorkel, Smitybilt winch, Baja designs 20in, wide cornering spots, S2 rear. Deaver expedition series stage 3 rear leaf.
    curious do you run a voltage booster at all ?
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    HKB Electronics
